GT32 Electronic Steering Wheel
The GT32 Electronic Steering Wheel transmits the status of 8 push buttons and 3 rotary switches through a fully configurable CAN connection, plus 2 additional push buttons via free contact connections. It also supports 2 optional carbon fibre paddle shifters with a precise magnetic system for reliable, high-quality gear shifting.
Why Choose the GT32 Steering Wheel
The GT32 Steering Wheel delivers professional-grade control with fully programmable buttons, rotary switches, and RGB LEDs, giving you the flexibility to tailor every detail to your needs. It’s built for precision, reliability, and total confidence behind the wheel.
Buttons & Rotary Switches:
  • Fully reconfigurable via Race Studio 3
  • Configurable as momentary, toggle, or multi-status inputs
  • 2 additional push buttons available via free contact connections
RGB LEDs:
  • Programmable and customisable
  • Frames and backlight icons
  • Continuous and dual-blinking modes available
  • Configurable brightness levels
Other Features:
  • Optional magnetic carbon fibre paddle shifters
  • ECU CAN connection
  • ON/OFF function with status restore option
Choose Your GT32 Version
Standalone: GT32 is available in a completely standalone version that connects via CAN to any ECU.
Expansion: GT32 CAN Open Steering Wheel is available as an expansion for the PDM32/08 Power Distribution Module, providing seamless integration into a complete Aim electronics system.
Push Button Configuration
Every LED and button can be fully configured in Race Studio 3 to match your exact requirements:
  • Momentary: Active only while the button is pressed.
  • Toggle: Switches state (ON/OFF) with each press.
  • Multi-Status: Cycles through values or states with successive presses.
Additional configuration options include response based on press length or predefined conditions.
CAN Output
The CAN output function allows full customisation of how data from the steering wheel is transmitted. Settings include:
  • Number of bytes allocated
  • Data length code
  • Byte order
  • Frequency from 1Hz to 100Hz
CAN Messages Configuration
The GT32 Steering Wheel transmits button and switch statuses, either at fixed frequencies or whenever a change occurs. CAN message parameters such as frequency, IDs, baud rate, endianness, and content can all be freely configured. Button states at power OFF can be restored at the next power ON.
In standalone mode, the GT32 Steering Wheel can also manage a CAN input protocol, providing LED feedback (such as colour changes) based on received information.
Additional accessories can be added to your GT32 to expand the system
capabilities:
  • Additional Controls: In expansion mode, the GT32 can also manage an Aim display connected to a PDM32 or PDM08 Power Distribution Module.
  • Replaceable Inserts: A wide range of inserts are included in the kit, allowing you to customise the GT32 to your specific needs.
  • Custom LED Backlighting: RGB LEDs can be managed through math channels, triggered by push button status or feedback from external devices. They can be set as solid or blinking at variable frequencies and brightness levels.
  • Precise & Solid Shifting: The new optional magnetic carbon fibre paddle shifters deliver high accuracy and tactile feedback, providing confidence during both upshifts and downshifts. Shifters can be configured through dedicated free contact pins or CAN message communication.
  • Diameter: 320mm
  • CAN Connections: 1
  • Body: Anodised Aluminium
  • Push Buttons: 8 push buttons in CAN + 2 push buttons free contacts
  • Rotary Switches: 3 rotary switches with RGB backlights
  • Connectors: 1 Autosport 22-pin male connector
  • Dimensions: 320 x 176 x 43 mm
  • Configuration: Via USB-C
  • Paddle shifters: CAN Messages and free contacts (optional)
  • Weight: 2,600g
  • Power Consumption: 500mA
Harness Options
GT32 User Guide
GT32 Tech Sheet
Standalone Tech Sheet
GT32 Steering Wheel
SW4 270/280 Formula Steering Wheel
  • 10 Push Buttons
  • Rotary Switches
  • Suits GT Race Cars
  • Sturdy & Durable
  • CAN Connection
  • ECU Connection
  • Data Logging
  • Rotary Switches
  • Removable Handle Grips
  • Compact Display
  • CAN Connection
  • ECU Connection
  • Data Logging
  • Rotary Switches
  • Compact Display
  • Dimensions: 320 x 176 x 43mm
  • Weight: 2,600g
  • 270 Dimensions: 270 x 183.5 x 42.6mm
  • 280 Dimensions: 280 x 183.5 x 42.6mm
  • Weight: 2,400g
  • GT320 Dimensions: 320 x 183.5 x 42.5mm
  • GT350 Dimensions: 350 x 183.5 x 42.5mm
  • Weight: 2,600g
  • GT32 Steering Wheel
  • Chosen 270 or 280 Steering Wheel
  • Chosen GT32 or GT350 Steering Wheel
  • Diameter: 320mm
  • Paddle Shifters: CAN messages and free contacts (optional)
  • Push Buttons: 8 push buttons in CAN & 2 push buttons free contacts
  • Body: Anodised aluminium
  • Shift Lights: 8 configurable RGB LEDs
  • Ambient Light Sensor: Yes
  • CAN Connections: 3
  • ECU Connection: CAN
  • ECU Compatibility: 1,000+ industry-leading ECUs
  • Expansion CAN Connection: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam, RIO Module, GS-Dash, Memory Module
  • Connectors: 1 Deutsch Autosport 22-pin male connector
  • Push Buttons: 10 push buttons & 3 rotary switches (all with RGB backlights)
  • Internal Memory: 4GB
  • Displays sold separately
  • Display: 4.3" TFT
  • Contrast: 800:1
  • Brightness: 800 cd/m2
  • Display: 5" TFT
  • Contrast: 800:1
