Aim MXP 1.3 6" TFT Car Dash Display Logger
Choose Accessories
Advanced Motorsport Dash Logger
The MXP car dash display logger has a 6" TFT digital display, which has been designed to acquire and display data coming from the ECU. It is an ideal choice for racers who want valuable data at their fingertips but might be limited by space in the cockpit.
Note: The MXP Strada option is also available with road icons to suit a variety of vehicle applications.
Why Choose the MXP 6" Car Dash Display & Data Logger
The Aim MXP 1.3 is a compact, but powerful motorsport display and data logger. It offers real time data on its 6” TFT screen, has customisable display layouts, lap timing capabilities thanks to the GPS09 Module (included in the kit),and is compatible with a range of Aim devices and expansions for the ultimate setup.
Connecting the MXP 1.3 dash to your car's ECU is simple. You can sample dozens of channels straight from the ECU. This is usually the quickest and easiest setup, needing only a cable connection to the ECU instead of multiple connections and analogue sensors.
The sampled data will depend on your actual ECU, but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel ratio). The list of available ECU drivers is constantly updated and upgraded, and includes over 1,000 different ECUs.
Two Digital Outputs
The MXP car dash display logger features two digital outputs. Each of them can give an output of 1 amp at 12 volts. They can be configured to be turned on/off depending on the value of the analogue or digital inputs. They permit automatic running of external systems such as switching on/off additional lights, activating/deactivating a cooling fan or circulation pumps when a certain event happens.
With the CAN output, you can also send messages directly to an existing CAN network to improve the range of vehicle control possibilities.
The MXP display logger also comes with 5 RGB LEDs, allowing you to customise colours, alarm types (solid or flashing), flashing frequency and accompanying text messages. Alarm priorities can be set to suit your specific requirements.
Pre-Configured Pages
With a high contrast 6" TFT display, which is fully configurable, you can create and customise pages/displays to suit your requirements. Swapping pages can be managed by pushing one or two push buttons. An ambient light sensor adjusts the backlight for optimal brightness, ensuring clear visibility in all lighting conditions.
Two analogue camera inputs are available to switch your display into a mirror camera, through a push button command or event management. The camera is sold separately.
GPS Options
The included GPS09 module connected via CAN to the MXP dash logger makes lap time calculations and track position analysis easy. With 4,000+ worldwide tracks already stored with the start and finish line coordinates, you will have no problem when you're on the track.
As soon as the MXP is turned on, the GPS module will locate its position, identify track line coordinates and start immediately sampling lap and split time. If the track is not in the database, you can easily add the start/finish line coordinates to the MXP using our Race Studio 3 software.
The GPS Module is available with cable lengths of 50cm, 1.3m, 2m or 4m, or a roof version with 2m or 4m length cables.
Please Note: A 37 pin harness comes standard in the kit. Should you need more data, you can add our 22 pin harness as an optional extra.
- All channels
- ECU drivers
- Math channels
- Display pages
- Digital outputs
- Alarms
- Shift lights
- Expansions
MXP 1.3 Dash
Harness
GPS Module with Cable
USB Cable
| Specs |
MXT Dash Display Logger
MXG Dash Display Logger
MXP Dash Display Logger
MXS Dash Display Logger
