Apuntar 5" Pantalla de tablero TFT con iconos de carrera para PDM08/PDM32
Compact PDM Display
The 5" PDM display with race icons is one of the most widely used PDM displays on track around the world. Its compact size makes it suitable for use as a replacement unit for those supplied with the Aim PDM kits or an upgrade for PDM kits that do not include a dash display.
Why Choose the 5” PDM Display
The 5" PDM display is a TFT dash display suitable for replacing all of the dashboard gauges and warning lamps. The displays are available in 5", 6" or 10" versions and with "Road" or "Race" icons. All versions have full user-configurable displays and offer a range of layouts.
Please Note: The 5" dash display is ONLY for use with Aim PDM kits and can not be used as a stand-alone dash display.
Display with Race Icons
The dash has a 5" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels.
Race icons allow you to apply conditions to the LED icons, such as fuel, engine, oil, lights and more.
Add extra devices to your system to give additional data to improve your racing performance, such as a GPS Module, Channel Expansion, TC Hub, SmartyCams, Lambda Controller, Formula Steering Wheel, TPMS System and keypads.
The 5" race display also doubles up as a reversing mirror using a separately available camera—ideal for cars with limited rear vision. You can add up to 2 cameras for both front and rear views. The camera is sold separately.
5" PDM Dash Display with Race Icons
