Aim Cable de conexión de 5 pines macho a hembra 712-712
Connect Your System
The Aim 712-712 patch lead is a durable extension cable with 5-pin male and female ends designed for connecting devices or expanding existing wiring in your Aim data system. These cables use the metal Binder 712 screw-on connectors with 5-pins in the housing, always ensuring reliable signal transmission.
Why Choose the Aim 712-712 Patch Lead
Aim CAN cables link modules or hardware on the Aim-specific CAN system (Controller Area Network). This lead simplifies installation and setup, allowing easy connection between modules, expansion hubs, or sensors without complex rewiring. It’s ideal for clean, organised wiring layouts.
The 5-pin male to female lead is available in multiple lengths and is compatible with Aim systems such as Channel Expansion Hubs, ECU Bridge, Lambda Controller, GPS Module, Data Hub, and any other peripheral hardware to a Data Hub. Essentially, the 712-712 patch lead can be used to extend your connection or integrate additional modules, ensuring flexibility and reliability across your Aim racing setup.
Note: These cables transfer data or power from one Aim component to another. It should not be confused with the CAN system in your car's factory wiring. They are separate CAN systems. Only in specific cases will an Aim CAN component interface with a vehicle CAN component, such as linking vehicle ECU data to a data logger.
Cable de conexión macho a hembra 712-712
