    Aim 719 (Plastic) Binder Plug - AimShop.com
    P-719
    £10.00
    £10.00
    The Aim 719 binder plug 4 pin is ideal for replacing damaged plugs or for adding additional sensors or extension cables to your Aim system.
    Key Features:
    Suitable for Aim sensors 4 pin  plastic Binder
    Ideal for adding to your system
    The Aim 719 binder plug 4 pin is ideal for replacing damaged plugs or for when adding additional sensors or extension cables to your Aim system. The plug has four pins.
    Ideal for replacing broken plugs or when adding sensors to your Aim system.
    Fits Aim 719 cables and sensors
    • 719 Plastic Binder Plug
    • 1 x 719 Plastic Binder Plug
    • Videos de soporte
    • Guía de productos PDF
    • Convertirse en embajador
    • Chat y soporte en vivo
