Aim 719 (Plástico) Tapón de carpeta
Connect Your System
The Aim 719 Binder Connectors are robust, reliable and perfect for shortening cables, making custom length cables, or adding additional sensors or extension cables to your Aim system.
Why Choose the Aim 719 Binder Plug Connector
The Aim 719 Binder Plug is a high-quality plastic connector available in male or female options, with 4-pins to suit your motorsport setup. The 719 Binder Plug is the ideal accessory for replacing existing connectors, adapting the length of the cable or adding sensors to your setup.
Chosen 719 Binder Plug
