    Aim Brake Pressure Sensor 0-100 Bar - AimShop.com
    0-100 Bar
    4-Pin 719 Male Binder
    S-P-B
    £190.00
    0-100 Bar
    Product Image
    £190.00
    The Aim 0-100 bar pressure sensor is suitable for oil and fuel pressure readings and can read pressures up to 100 bars. This sensor will monitor brake pressure levels for optimum performance accurately.
     0-100 Bar 4 pins 719 male binder
    The Aim 0-100 Bar brake pressure sensors are fitted with male four pins black 719 binder plug connections to suit all Aim loggers and dash display/loggers.
    The sensors can be easily installed in a -3 brake line using a three-way T-piece. It can also use them for measuring other pressures too high for the 0-10 Bar sensor. Available with an M10 or -3 JIC (3/8-24 UNF) thread.
    • Supply: 8-16V
    • Consumption: < 10 mA
    • Sealing: IP66
    • Weight: 30g
    • Cable Length: 400mm
    • Aim Brake Pressure Sensor 0-100 Bar
    Technical sheet Race Studio 3
    • Videos de soporte
    • Guía de productos PDF
    • Convertirse en embajador
    • Chat y soporte en vivo
