Taipan to Solo 2 DL Extension Lead
The Aim Taipan Solo 2 DL extension lead is a 50cm connection cable designed to connect the Taipan ECU to the Solo 2 DL data logger. One end has a 7-pin 712 male binder connector for the Solo 2 DL, while the opposite ends feature male and female JST connectors for the Taipan ECU.
Why Choose the Aim Taipan Solo 2 DL Extension Lead
The Aim Taipan Solo 2 DL extension lead makes it easier to connect the Solo 2 DL logger and Taipan ECU in your setup without strain on the connectors. Its compact 50cm length offers practical reach for most installations, and the construction ensures dependable performance under difficult motorsport conditions. The cable allows integration into your system, helping maintain organised and efficient wiring throughout your Aim racing setup.
Solo 2 DL Connector
  • 712 male binder connector - 150mm cable
4P Male JST Connector
  • 04T-JWPF-VSLE-S
  • PIN SWPT-001T-P025 - 350mm cable
4P Female JST Connector
  • 04R-JWPF-VSLE-S
  • PIN-SWPR-001T-P025 - 350mm cable
  • Black - GND
  • White - CAN EXP H
  • Blue - CAN EXP L
  • Red - 12V
SKU: C-SOLO-P
Harness Options
Taipan User Guide
Taipan Tech Sheet
Videos
Cargar video: Plug & play installation of the Cobra ECU (now Taipan)
