AIME EV04S SPEED Sensor Split Cable Patch Patch
Double Speed Sensor Split Cable
The Aim EVO4S double speed sensor split cable enables the connection of 2 different speed sensors into a single input on the EVO4S data logger. It features a 4-pin 712-type male Binder connector for the logger end and splits into 2 compatible sensor connections, professionally made to ensure long-lasting reliability.
Why Choose the Double Speed Sensor Cable
The split cable simplifies your wiring layout by allowing 2 separate speed sensors, such as wheel speed or ground speed, to be read by the EVO4S without requiring multiple logger ports. It is ideal when you want dual speed inputs for applications like front/rear wheel speed or differential speed monitoring.
Speed Sensor Split Cable - 712 Male to x2 712 Female
