Aim Tapón de soldadura de repuesto para controlador Lambda LCU-One
Connect Your LCU-One Lambda Sensor
The Aim Weld-On Bungs create a permanent and easy mount for your LCU-One Lambda Sensor fittings. The Weld-On Bungs are ideal for retrofitting and testing applications. It is a female, steel thread that measures at 24.7mm with a natural finish. This ensures that it will last longer and allow you to expand and improve your setup with ease and security. The Bung can also be paired with the Bosch LSU 4.9 Probe, which is specifically designed to measure the proportion of oxygen in exhaust gases.
Weld-On Bung
