AIME MX2E Kit de registrador de plugs Dash para Lotus Elise/Exige
Choose Accessories
The Lotus OEM Upgrade: MX2E
The Aim MX2E provides a significant upgrade for Lotus Elise or Exige dashes, offering a seamless plug & play solution that provides real time data and enhanced functionality to transform your driving experience.
Why Choose the MX2E Lotus Dash
The Aim MX2E offers a comprehensive upgrade to your Lotus dash, combining modern aesthetics with advanced data logging capabilities. At the push of a button, your dash can be customised from daily driving to a track day data logger. Whether you're on the track or on the road, the MX2E plug & play dash provides everything you need to enhance your driving experience.
Advanced Data Acquisition
The MX2E dash logger gathers data from the car’s ECU, the integrated GPS module and any additional sensors and modules. This data is then displayed directly on the Lotus dash in real time, displaying key performance metrics like RPM, throttle position, temperatures, pressures, lap times and more.
The included GPS module provides accurate GPS speed, lap timing, and track mapping. You can view this track data directly from the dash or transfer it via Wi-Fi connection to our Race Studio 3 Software for more in-depth analysis. This will allow you to visualise graphs, histograms and tables to compare lap and session performance.
The MX2E dash has 2 types of displays, both available with analogue or digital: road or track. There are 16 display layouts to choose from with 4 different colour options, which can be customised to suit your preferences.
There is also a wide range of icons available on the display, allowing you to easily see important information whilst you’re driving: rear fog light, position lights on, ABS on/malfunctioning, ABS off, hand brake, engine off, pressure low, seat belt not fastened, airbag off.
The MX2E dash features a total of 18 solid LEDs: left or right direction indicators, 10 shift lights LEDs and 6 status information LEDs showing hand brake on, fuel level low, immobiliser on, position lights on, high beam on and engine problems.
Compatible Expansions
The MX2E plug & play dash logger is compatible with various expansions and modules to enhance performance and expand on data collection. Compatible expansions include:
- Lambda Controller: Monitor your air-fuel ratio for optimal engine performance.
- Channel Expansion: Add more sensors to capture additional data points.
- SmartyCam Cameras: Integrate video with data overlay for comprehensive analysis. Analogue camera input also allows you to swap your display into a mirror camera through push button command or event management.
Lotus Compatibility
The MX2E is compatible with Lotus Elise and Exige dashes that are fitted with Toyota engines:
- 2004-2007: Requires an additional adapter harness (airbag-equipped cars only).
- 2008-2020: Direct fit.
Harness Options
MX2E Dash
Cluster
GPS Module
MX2E Fixings
