Aim PDM08 Data Logging Kit
The Aim PDM08 system combines advanced power management, real time data display, and precision GPS tracking into a single integrated solution. Its 8-channel power distribution module replaces traditional fuse boxes and relays, while the fully configurable TFT display presents critical information through customisable layouts and intuitive road icons. When paired with the onboard GPS module, the system also delivers accurate lap timing and track-mapping capabilities for a complete electronics package.
Aim PDM08 Power Distribution Module
Why Choose the PDM08 Road Dash Display Kit
The Aim PDM08 is an 8-channel advanced power distribution module designed to power a multitude of vehicle circuits, removing the need for traditional fuse boxes and relays. It allows for a simplified wiring harness with increased reliability and control functions. Paired with a TFT Display with Road Icons, a fully configurable display with a range of layouts to choose from, and a GPS Module that provides easy lap timing and lap position for track mapping, this kit is the ultimate set-up for full vehicle control and performance improvement.
The PDM08 features 8 high-side outputs: 1x with a series diode rated up to 20A, 1x rated up to 25A, and 6x rated up to 15A, with a total continuous max current of 100A. Each output provides feedback to the data logger to provide vital information such as open circuits, short circuits, high/low voltage, and the number of fault retires. The time between the retires is user-definable. All outputs can be configured as PWMs for a soft start/stop. All of the PDM circuits can be set up and monitored via the Race Studio 3 software.
The PDM also features 6 analogue/digital inputs and 2x speed inputs, and can receive and record data from the following sources:
  • Digital/analogue inputs
  • Internal nine-axis EMU
3 variations of PDM Dash Display in 5, 6 and 10-inch
PDM Dash Displays with Road Icons
All versions have fully user-configurable displays and offer a range of layouts, and are available with "Road" or "Race" icons. Road icons with this particular kit allow you to apply conditions to the LED icons.
Cargar video: Delta times LED display feedback on the 5 inch PDM Display
Cargar video: Integrated shift light array interface and customisable alarms for the PDM Dash Displays
Cargar video: Pre-configured dash display screens for the PDM Dash Displays.
Pre-Configured Pages
The Aim PDM Display can show the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can customise pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy; just use the push buttons.
Integrate a Reverse Camera
By connecting an Aim PDM08 to your Aim PDM Display - giving it the power to log your data - you can download your data and with Race Studio 3; create, modify, delete, import and export configurations of:
  • All channels
  • ECU drivers
  • Math channels
  • Display pages
  • Digital outputs
  • Alarms
  • Shift lights
  • Expansions
GPS Options
The GPS09 Module provides easy lap timing and lap position for track mapping. The PDM has over 4,000 tracks in the database, so once you arrive at the track, the system already knows the timing points so that you can arrive and drive.
Note: The GPS09 Module is available with cable lengths of 0.5m, 1.3m, 2m or 4m to suit different applications. We also have an option for a roof-mounted version, which is available with 2m or 4m length cables. Both versions come with a 5-pin 712 male binder connector.
Aim CAN Expansion Keypads
Optional Wiring Solutions
  • LEDs: 8 RGB LEDs + 1 PDM ON + 1 PDM STS (Status)
  • Inputs: 6 fully configurable (max 500Hz each), pullup + 12V, + 5V, pull down & analogue/digital
  • Speed Inputs: 2
  • Lin Bus: 1
  • CAN Connections: 3
  • Internal Memory: 4GB
  • External Analogue Camera Input: No
  • Connectors: 1 AMP connector, 1 Amphenol SurLok connector & 1 Rosenberger connector
  • Body: Anodised aluminium
  • Dimensions: 161 x 100.6 x 50.6mm
  • Weight: 500g
  • Waterproof: IP65
Power Outputs
  • 1 with a series diode rated up to 20A
  • 1 rated up to 25A
  • 6 rated up to 15A
  • Protected For: over-voltage, under-voltage, undercurrent, over-temperature
  • Total Max Current: 100A
SKU: PDM-8
Aim PDM Display
  • Display: 5" / 6" / 10" TFT
  • Waterproof: IP65
GPS Module
  • GPS: 25Hz
  • External Power: 5-15V
  • Inertial Platform: No
  • Weight: 60.5g
SKU: GPS
Pinouts
MXS 5 inch PDM display pinout 6" PDM Display Diagram GPS09 pinout
  • PDM08
  • Pantalla elegida
  • Black 35-Pin Plug & Pins
  • SurLok Power Connector
  • PDM08 LVDS Connector Cable
  • Download Cable
  • CAN Expansion Cable
PDM08 User Guide
PDM08 Tech Sheet
5" PDM Display Tech Sheet
6" Hoja de especificaciones técnicas de la pantalla PDM
10" Hoja de especificaciones técnicas de la pantalla PDM
GPS09 Pinout
What does a PDM do?
At Aim, we have 2 PDM modules to suit different vehicle setups: PDM32, which has 32 output channels for more complex setups and PDM08, which has 8 output channels for simpler or compact setups. The 'best' PDM depends on how many outputs you need and the size of the setup.
Can PDMs be used on road cars?
Absolutely! Although PDMs are primarily used in motorsport applications, they can be used to replace traditional relay and fuse setups. In fact, PDMs can work with wipers, indicators and more.
The PDM08 has 6 analogue or digital inputs and 2 speed. You can add a CAN Keyboard, giving between 4 and 15 buttons, wireless wheels giving up to 8 buttons and 2 rotary inputs, and RIO modules, which can give 8 high or low inputs and 11 low-only inputs.
Can indicators be set to auto-cancel in a road-legal car?
Yes, you can use the built-in logger roll, pitch and yaw to do this. The yaw increases when turning right and decreases when turning left. If you want the right indicator to cancel, you can use a function with yaw less than -5, and to cancel left turn, the function would have a yaw greater than 5.
If front wipers are on, can rear wipers come on when reverse is selected?
Absolutely! If the front wipers are on, you can configure the PDM to activate when reverse is selected to have front and rear wipers working at the same time. This will need to be configured in the PDM.
