Aim Cable de alimentación externa de 7 pines para SmartyCam & Micrófono integrado
Power Your System
The Aim SmartyCam Harness provides a constant power supply from a 12V battery system using two unterminated wires, with an integrated microphone to improve sound quality from your SmartyCam footage. The cable is available in 2 or 4 metre lengths and is compatible with the Aim SmartyCam 3 & 4 Corsa, 3 GP and 2.2 GP/GP HD.
Why Choose the SmartyCam Microphone Power Cable
The power cable is a useful accessory for when you want the reassurance of having the camera powered from a 12V battery system. The integrated microphone can be placed in any position you wish, inside or outside your vehicle and in a position where the microphone won't just pick up wind noise.
Please Note: This connection cable is not required if you are connecting the SmartyCam to a logger or dash, as the power will be supplied to the camera through the CAN connection.
SmartyCam 7-Pin Power & Microphone Cable
