Aim Soporte en U para cámara tipo bala SmartyCam
Mount Your System
The Aim SmartyCam Bullet Camera U Bolt Mount is designed to mount a SmartyCam bullet camera to a vehicle's roll bar, railing or tube that has a diameter between 0.5 to 1.2 inches. It is suitable for SmartyCam 2.1, 2.2, 3 and 4 Dual and GP models.
Why Choose the Aim Bullet Camera U Bolt Mount
The Aim SmartyCam Bullet Camera U Bolt Mount is a versatile way to secure a bullet camera to a range of vehicle setups. The mount is easy to set up; simply attach the U bolt to the vehicle, and secure using the lock nuts for a secure fit. The ball and socket system allows you to easily adjust your camera angle, while the rubber insert minimises vibration, ensuring you get the best recordings of your laps.
