Mount Your System
The SmartyCam U Bolt Mount is used for mounting the SmartyCam GP recording box system to a vehicle’s roll bar, railing or tube that has a diameter between 0.5 and 1.2 inches. It is compatible with the SmartyCam GP 2.1, 2.2 & 3 models, including the GP Pro.
Why Choose the SmartyCam Recording Box U Bolt Mount
The Aim SmartyCam U Bolt Mount is used to secure a SmartyCam GP recording box in a convenient location on a roll bar, railing or tube. The mount is easy to set up; simply attach the U bolt to the vehicle, and secure using the lock nuts for a secure fit. The ball and socket system allows you to easily adjust where the recording box sits for optimum positioning and has been designed to withstand the rigours of motorsport.
  • For use with SmartyCam GP 2.1 & 2.2 & 3 recording box
  • Ball & socket adjustment system
  • Includes a rubber insert and lock nuts for a secure fit
  • Suitable for 0.5 to 1.2" bar
  • Designed to withstand the rigours of motorsport
  • U bolt
  • 90mm arm
  • Clamp base with ball
  • Mounting bracket
  • Locknuts
  • Washers & screws
SKU: SM-UB-GP-R
Part Number: X90KSGPTP
