Data Logging Steering Wheel
The Aim Formula Steering Wheel 4 GT320/GT350 is our most advanced steering wheel to date. It has an internal data logger with complete configuration, removable grips, rotary switches and a long list of fully compatible ECU and CAN connectivity options.
Why Choose the GT320/350 Steering Wheel
The Aim Formula Steering Wheel GT320/GT350 is used for GT and closed cockpit cars where space is at a premium. The internal data logger is fully configurable and suitable for many different motorsports. It has been designed to acquire and display data coming from the ECU with over 1,000 fully compatible ECU protocols.
Our Formula wheels come in a range of sizes (270, 280, GT320 & GT350). The difference between the Formula Steering Wheel 4 GT320 and the GT350 is the overall size of the wheel; the Formula Steering Wheel GT350 is 30mm larger to meet every driver's requirements.
Connecting the Aim Formula Steering Wheel GT320/GT350 to your ECU is simple. You can choose between an Aim Harness or craft your own harness using the existing Deutsch cable connected to the module to sample dozens of channels straight from the vehicle ECU. This is usually the quickest and easiest setup, needing only a cable connection to the ECU instead of multiple connections and analogue sensors.
The sampled data will depend on your actual ECU, but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel ratio). The list of available ECU drivers is constantly updated and upgraded, and includes over 1,000 different ECUs.
With the CAN Output, you can also send messages directly to an existing CAN network to improve the range of vehicle control possibilities.
Display & Push Buttons
The Formula Steering Wheel 4 GT320/GT350 has a high contrast 5" TFT display that is fully configurable and resistant to sunlight glare. With the ambient light sensor, the display is easy to read night and day.
The Formula Steering Wheel 4 GT320/GT350 has 10 push buttons and 3 rotary switches, all backlit with RGB LEDs for enhanced usability.
Flexible Alarms
The Aim SW4 GT320/GT350 Formula Steering Wheel has 8 configurable shift light RGB LEDs and 4 configurable alarm RGB LEDs. You can choose the conditions and colours: Select a solid alarm or flashing one, and the flashing frequency. You can also choose to have an accompanying text message and set the alarm priorities.
Optional Extras
  • Clutch Paddles: Add left and/or right clutch paddles directly from the options at the top of the page to suit your driving style.
  • GPS Module: Connected via CAN, the GPS Module makes lap time calculation and track position analysis easy.
  • SmartyCam: An onboard motorsport camera that records video and overlays critical performance data for real time driver feedback and post-session analysis.
  • CAN Connections: 3
  • ECU Connection: CAN
  • ECU Compatibility: 1,000+ industry-leading ECUs
  • Shift Lights: 8 configurable RGB LEDs
  • Ambient Light Sensor: Yes
  • Expansion CAN Connection: GPS Module, Channel Expansion, TC Hub, Lambda Controller, SmartyCam, RIO Module, GS-Dash, Memory Module
  • Connectors: 1 Deutsch Autosport 22-pin male connector
  • Power Consumption: 500mA
  • Internal Memory: 4GB
  • Push Buttons: 10 push buttons & 3 rotary switches (all with RGB backlights)
  • Display: 5" TFT
  • Contrast: 800:1
  • Brightness: 800 cd/m2 - 1,200 Lumen
  • GT320 Dimensions: 320 x 183.5 x 42.5mm
  • GT350 Dimensions: 350 x 183.5 x 42.5mm
  • Weight: 2,600g
SKU: FSW4
Aim SW4 GT320/GT350 Formula Steering Wheel Diagram
Formula Steering Wheel GT320 harness pinout
GT320 Tech Sheet
GT350 Tech Sheet
GT32 Steering Wheel
  • CAN Connection
  • ECU Connection
  • Data Logging
  • Rotary Switches
  • Removable Handle Grips
  • Compact Display
  • CAN Connection
  • ECU Connection
  • Data Logging
  • Rotary Switches
  • Compact Display
  • 10 Push Buttons
  • Rotary Switches
  • Suits GT Race Cars
  • Sturdy & Durable
  • Weight: 2,600g
  • Weight: 2,400g
  • Dimensions: 320 x 176 x 43mm
  • Weight: 2,600g
  • Chosen GT32 or GT350 Steering Wheel
  • 280 Steering Wheel
  • GT32 Steering Wheel
  • Diameter: 320mm
  • CAN Connections: 1
  • Configuration: Via USB-C
  • Paddle Shifters: CAN messages and free contacts (optional)
  • Rotary Switches: 3 rotary switches with RGB backlights
  • Connectors: 1 Autosport 22-pin male connector
  • Push Buttons: 8 push buttons in CAN & 2 push buttons free contacts
  • Body: Anodised aluminium
  • Display: 5" TFT
  • Contrast: 800:1
  • Display: 4.3" TFT
  • Contrast: 800:1
  • Displays sold separately
What is the Aim SW4 Formula Steering Wheel collection?
The Aim Formula SW4 collection is a range of high-performance steering wheels that are designed for single-seater motorsports. They are made to be versatile and compatible with many different racing applications and include a range of key features.
The Aim SW4 range comes in multiple sizes and has a memory of 4GB. It allows for real time data to be shown, making it easy for drivers to see where they are and to make changes based on it. You can also expand your system with GPS modules and the SmartyCam 3 through its CAN connectivity. This steering wheel is the perfect product for racers looking to upgrade their driving and data logging capabilities.
Are SW4 Formula Steering Wheels compatible with Aim devices & data logging systems?
Aim SW4 Steering Wheels are compatible with other Aim devices and data logging systems, such as the ACC3 Analogue CAN Converter, SmartyCam Cameras and various sensors. This allows for a more detailed and advanced data collection and analysis, making it a very versatile product for different motorsport applications.
What sizes do the Aim SW4 Steering Wheels come in?
The Aim SW4 Steering Wheel range is available in 4 sizes (270, 280, 320 and 350mm) for different racing applications and cockpit space available. Please see our SW4 guide for more information on which sizes are best-suited to your setup.
How do you install a Formula Steering Wheel in a cockpit?
Regardless of which steering wheel you are most interested in, connecting the Formula 4 Steering Wheel to the vehicle’s ECU is extremely easy. Start by securely mounting the wheel to your vehicle. Once the wheel is in place, you can then connect it to the ECU using the Deutsch connector harness.
After the wheel is in place and connected, Race Studio 3 software can be used to customise display pages, alarms and shift light settings according to your preferences. Please test the setup thoroughly to ensure that all functions are working correctly.
