AIM TAIPAN UC PUENTE
Choose Accessories
Why Choose the Taipan UC Bridge Tuner
The UC Bridge Tuner has been specifically designed to programme, configure and customise an unprogrammed Taipan ECU, making it an ideal tool for professional tuners and workshops. The Tuner connects the ECU's CAN bus to a computer's USB port.
Tuner License
The UC Bridge Tuner is available with the Tuner License. The Tuner License unlocks advanced functionality for professional tuners and workshops. It provides full control to:
- Create and modify maps: Build custom fuel and ignition maps tailored to specific needs or performance goals.
- Configure ECU parameters: Adjust detailed settings and configurations before transmitting them to the ECU.
UC Bridge Tuner Functionality
The Taipan ECU comes with some basic maps that already give you better performance than the stock ones. Some highly professional tuners from around the globe offer specific maps that better fit your requirements, for example, managing different exhaust tubes and two injector kits etc.
You will require the UC Bridge Tuner for the following functions:
- Unlocks full editing capability: Create, modify, and optimise maps from scratch.
- Gives access to advanced ECU configuration settings.
- Enables sending complete, customised setups directly to the ECU.
Once the unprogrammed Taipan ECU has been configured with a dedicated brand or model, it cannot be changed. You will be able to modify the maps written into the ECU, but the brand or model which has been configured cannot be changed.
Our leading motocross ECU provides the ultimate control in ignition, ignition phase, start maps, launch control, traction control with altitude, and engine temperature corrections.
UC Bridge vs UC Bridge Tuner
The UC Bridge and the UC Bridge Tuner differ mainly in their purpose and level of functionality.
The UC Bridge, intended for riders and end-users, allows you to receive maps from your tuner, flash them into the ECU, monitor system logs such as exceptions or errors recorded by Taipan, and make limited adjustments like applying fuel injection corrections across different RPM ranges.
By contrast, the UC Bridge Tuner is designed for professional tuners and workshops, unlocking full control over the ECU. It enables the creation and modification of custom maps, advanced configuration of ECU parameters, and the ability to transmit complete, tailored setups directly to the ECU.
In short, the UC Bridge is the tool for riders to use maps, while the UC Bridge Tuner is the tool for professionals to build them.
Please Note: For information regarding the UC-Bridge, please contact one of our Aim technical team for further information.
Videos
