Tyre Pressure Monitoring Solo 2 DL Kit
The Aim Tyre Pressure Monitoring System (TPMS) paired with the Solo 2 DL allows you to get the most precise lap times, accurate data on tyre pressures throughout your race, and alerts to changes in tyre pressure.
Why Choose the TPMS & Solo 2 DL Kit
The Solo 2 DL displays instant speed, timing splits, live data and delta lap times on a high-contrast display with an accuracy of up to two-hundredths of a second. You can see your exact racing line, compare it to optimal lines for faster lap times, track the vehicle's movements and provide detailed data on acceleration, braking, and cornering forces.
The TPMS utilises robust sensors for each wheel, with high-resolution sensors that measure tyre pressure and temperature, transmitting securely coded data to the onboard receiver.
Pair these modules with direct ECU data logging for instant, trackside, or post-race analysis with all your logged performance data.
Cargar video: SmartyCam video footage showcasing Solo 2 DL in motorsport setup
Accurate Lap Timing, Real Time & Post-Session Review
The Solo 2 DL lap timer provides key information: lap times, lap count, delta times and predictive lap times. With over 4,000 tracks already loaded onto the database from across the globe, you can automatically select your nearest track based on your current position.
Log your vehicle’s ECU data for reviewing after a race day to help improve driver performance or vehicle set-up, and capture every lap in full HD and overlay lap and ECU data onto the footage for the ultimate lap-by-lap review.
TPMS kit with Solo 2 DL
Multiple Configurations
Constant braking, turning, and enormous rotational forces can lead to incredibly high-temperature build-up in the tyres. The TPMS is the ultimate tool for alerting drivers to a change in tyre pressures and providing data on how the tyre pressures alter throughout your races.
All sensors are pre-programmed in-house to be Set 1, Set 2, or Set 3 (or more if required), and these can be changed as needed with the Handheld Programming Unit.
The Solo 2 DL can also receive up to 10 configurations at one time, allowing you to switch among them through keys. Sample your data, including RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel).
Advanced Lap Times & Performance Analysis
The Aim Solo 2 DL is the most precise GPS lap timer in the world. With the ability to show your live delta times as you drive. Receiving data from 2 satellite constellations, GPS and Glonass, it also gives you a significant improvement in data, speed, and positioning precision.
Powering on requires only a few seconds, and lap times are calculated within 2/100 sec of tolerance.
The Solo 2 DL gives instant speed, timing, splits, live data and predictive lap times, and can be backlit in 8 available colours.
The Solo 2 DL has a sharp, high-contrast display which helps drivers easily identify the data displayed on screen, as well as 8 different backlight colours.
Whether it's used for point-to-point runs for rallying or a closed-loop track, the Solo 2 DL allows you to create a new temporary or permanent track layout too. Even if there is no track already, the device will create one for you.
Sample your data, including engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel).
TPMS App
TPMS sensor visual in car tyre
The Aim Tyre Pressure Monitoring System comes with a wiring harness, 4, 8, 12, 16, 20, or 24 sensors, and a CAN Receiver, which is compatible with race car applications and competitions.
The CAN Receiver utilises 1Mbit CAN (11bit), which has become the standard over the years for most professional ECUs, data loggers and dashboards within the motorsport and automotive sectors. The receiver is pre-coded with 4 sensors, and each sensor is labelled FR, FL, RR, and RL for each of the wheels of the car. All you need to do is connect your sensors to the correct tyre and all the data will be recorded on the receiver. You can overlay all of this data straight to your dash logger. Extra wheels can be clone-coded and used as sets of spares for pit changes, just clone a sensor manually using the Handheld Programming Unit.
Cargar video: SmartyCam Sport & Solo 2 DL data being analysed on Race Studio 3
Both the data recorded from the Solo 2 DL and the video from the SmartyCam 3 Sport can also be combined in our free analysis software, Race Studio 3. This allows you to review your driving and compare data such as speed, G-forces, throttle position and more, and acts as a performance tool to assist you in improving your driving skills by providing a visual reference for driving lines and technique.
Connections & Expansions
The Aim Tyre Pressure Monitoring System can be used with all our dash display loggers. You can add a 4x CAN connection multiplier and a GPS module or our SmartyCam cameras to your system.
While the standard CAN Receiver uses a precise radio link to all your sensors, with the address of each sensor pre-defined as to which wheel is being measured, the Handheld TPMS Programmer lets you read each wheel individually when in close proximity.
You can also attach a SmartyCam 3 to your kit, so when you log all your ECU data and merge it with your GPS information, you can transmit everything to your camera’s graphical overlay in Race Studio 3, synchronising all of your data over video.
TPMS App download
Free TPMS App
Quickly connect to the programming tool via Bluetooth without complex setups for easy programming of automotive tyre sensor replacements. It covers 95% of vehicles on the market, ensuring that no matter what car you drive, there's a corresponding programming option.
Download on iOS Download on Android
Solo 2 DL
  • Display: Graphical LCD
  • Integrated Track Database: Yes, over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
  • Multiple Configuration Management: Yes
Sensor Specifications
  • Sensor Pressure Measurement Range: 0-8,000 mbar
  • High-Frequency Modulation Mode: FSK
  • Sensor Temperature Measurement Range: 0°C to 125°C
  • Sensor Temperature Resolution: 1°C
  • Sealing: IP67
  • Battery Lifespan: Min 2 race seasons
  • RF Frequency: 433.92 MHz
  • High-Frequency Emission Power: <8dBm (50ohms)
Wire Colour Code
  • +12V: Red
  • Ground: Black
  • CAN+: Green
  • CAN-: White
CAN Bus Receiver
  • Baud Rate: 1000 kbps
  • DC: 12V-24V
  • Pressure Accuracy: +/-20 mBar
  • Connection output for CAN 2.0 1Mbps 11 bit
SKU: SOLO2-K3-TPMS-KIT-X47SOLO2DL02
  • Solo 2 DL
  • Cable icon
    Power Cable with AC Adapter
  • CAN Cable
  • Sensors (quantity selected at checkout)
  • Tyre Pressure Monitoring System CAN Receiver - AimShop.com
    1x CAN Receiver
    TPMS Harness
Solo 2 DL User Guide
Solo 2 DL Tech Sheet
TPMS User Guide
TPMS Tech Sheet
TPMS CAN Protocol
Videos
Solo 2 DL Overview
Cargar video: An in-depth review of the main features and functions of the Aim Solo 2 DL lap timer.
