Aim Cable de descarga USB a 712 de 3 pines
USB Download Cable
The Aim USB Download Cable provides a quick and reliable connection between your Aim PDM unit and your PC, allowing fast data transfer and system configuration through Race Studio 3 software. Featuring a 712 3-pin Binder connector and a standard USB interface, this cable delivers a secure connection with no adapters or wiring required.
Why Choose the Aim USB Download Cable
The Aim USB to 712 3-Pin Download Cable is the ideal solution for downloading logged data, providing the perfect compatibility and reliability expected from Aim. Fully compatible with Aim PDM systems supporting USB communication, it ensures a clean, direct link between your PDM and your PC for accurate data analysis.
Please Note: The USB to 712 3-Pin Download Cable is also compatible with EVO4 & EVO4S models.
712 to USB Download Cable
