Mount Your System
The Aprilia Motorcycle Bracket has been specifically designed to provide a simple and secure mounting solution for the Aim Solo 2 and Solo 2 DL Lap Timers. All the needed hardware to set up the mount is included with the bracket, so you can attach your Solo 2 Lap Timer with ease.
Why Choose the Aim Solo 2/2 DL Motorcycle Bracket
The Aim Solo 2/2 DL Motorcycle Bracket has been specifically designed for securely mounting your Solo Lap Timer onto your Aprilia RSV4 motorcycle. As all the components are included, it provides a quick and easy installation, so you can monitor your data and chase the results you want.
Please Note: The bracket is only compatible with the RSV4 original triple clamp.
Aprilia Motorcycle
Plug & Play Cable
A separately sold plug & play cable is also available for the following Aprilia motorcycle models and years:
  • Aprilia RSV4 RR/RF – 2017-2018
  • Aprilia RSV4 1100 – 2019-2020
  • Aprilia Tuono V4 RR/Factory – 2017-2020
If you are unsure whether this bracket will fit your motorcycle, don't hesitate to contact our team.
  • For Aprilia RSV4 motorcycles only
  • Mounting bracket for the Solo 2 & Solo 2 DL Lap Timers
SKU: APR-B
Part Number: X46KSARSV40
  • Soporte Aprilia Solo 2/2 DL
  • x1 Tornillo Allen de cabeza redonda M8x45mm
  • x2 tornillos Allen de cabeza plana M4x10mm
  • x1 Arandela dentada
  • x1 pasador de goma
Aprilia User Guide
