Aprilia RSV4 RR/RF, 1100, Tuono V4 RR Factory Aim Solo 2 DL & EVO4S Logger Plug & Play Cable
Choose Accessories
Aprilia Motorcycle ECU Connection
The Aprilia ECU Plug & Play Cable allows you to connect Aim Data Loggers, such as the Solo 2 DL, ECULog, XLog or EVO4S, to the Aprilia-specific connector. The Aprilia ECU Cable provides an easy plug & play connection to the motorcycle's ECU on one end, and uses a metal 712 screw-on binder connector with 7-pins on the other end, allowing ECU data to be logged.
Plug & Play Cable
The plug & play cable has been specifically designed for the following Aprilia motorcycle models and years:
- Aprilia RSV4 – 2017-2018
- Aprilia RSV4 1100 – 2019-2020
- Aprilia Tuono V4 – 2017-2020
Example Data Protocols
Example data protocols sampled can include RPM, gear, throttle position, wheel speed, low fuel level, ABS and many more. Refer to the user guide in the Downloads tab for a full protocol list.
Aprilia Solo 2 DL Plug & Play Cable
