BMW S1000RR y S1000RR HP4 AIM EVO4S Logger Plug & Play Cable
BMW Motorcycle ECU Connection
The BMW ECU Plug & Play Cable allows you to connect the Aim EVO4S Data Logger to the BMW-specific connector. The BMW ECU Cable provides an easy plug & play connection to the motorcycle's ECU on one end, and uses a metal 712 screw-on binder connector with 7-pins on the other end, allowing ECU data to be logged.
Plug & Play Cable
The plug & play cable has been specifically designed for the following BMW motorcycle models and years:
- BMW S1000RR – 2009-2014
- BMW S1000RR – From 2015
- BMW S1000RR HP4 – 2013-2014
Example Data Protocols
Example data protocols sampled can include RPM, gear, vehicle speed, front wheel speed, rear wheel speed, brake and oil pressure, throttle position, low fuel level, traction control, map menu and many more. Refer to the user guide in the Downloads tab for a full protocol list.
BMW EVO4S Plug & Play Cable
