Cable MyChron 6 USB 2.0 Tipo A Tipo C 1m
USB Cable Connection
Featuring USB Type-A to Type-C connectors, this cable allows you to connect to a battery charger of at least 2W to charge your MyChron 6 Lap Timer. The USB Cable also allows a quick and reliable connection between various Aim Data Loggers and your PC, allowing fast data transfer and system configuration through Race Studio 3 software.
Why Choose the Aim USB Cable
The USB Type-A to Type-C Cable is the ideal solution for downloading logged data, providing the perfect compatibility and reliability expected from Aim. Fully compatible with Aim data logging systems supporting USB communication, it ensures a clean, direct link between your data logger and your PC for high-speed, accurate data analysis.
With a cable length of 1m, it provides a reliable connection without excessive wiring, making it suitable for karting, motorcycle or compact track car setups.
