OptiMate Lithium Battery Charger
The OptiMate charger 0.8A – 14.4V is a compact yet powerful charger, maintainer, and tester designed for smaller 12.8V/13.2V lithium iron phosphate (LiFePO₄) batteries. Perfect for motorcycles, scooters, quads, and other light powersport vehicles, it delivers the same trusted OptiMate technology in a lower-output unit designed to match smaller battery capacities.
With its advanced Ampmatic™ microprocessor program, the OptiMate charger adjusts charge rate according to battery size and condition, ensuring safe, efficient, and precise charging. It doesn’t just charge – it balances cells, protects against overcharging, and maintains your battery at peak health, so your vehicle is always ready to ride.
Why Choose the OptiMate Charger 0.8A – 14.4V
The OptiMate charger 0.8A – 14.4V is the ideal choice if you want professional-grade battery care for smaller LiFePO₄ batteries. Its intelligent charging program doesn’t just top up your battery; it actively monitors, balances, and protects it, ensuring maximum lifespan and dependable performance.
For riders who store their vehicle over winter or leave it unused for weeks at a time, the OptiMate charger 0.8A offers peace of mind. Its automatic maintenance mode delivers exactly the right current to keep your battery at 100% without risk of overcharging, so your vehicle will always be ready to start when you are.
Compact, efficient, and easy to use, this charger is trusted worldwide by motorcyclists and powersport enthusiasts who want the very best for their lithium batteries. With the OptiMate charger 0.8A – 14V, you’re not just buying a charger – you’re protecting your investment and guaranteeing long-term battery performance.
  • Operating Temperature: -40°C - 40°C
  • Programme Control: Ampmatic TM microprocessor
  • Input current Max: 0.55A at 5.0A
  • Output Current (bulk charge): 0.4A - 5.0A
  • Reverse Drain Current: Less than 0,001A
  • Automatic Desulphation: Multistage (high voltage, turbo and pulsed mode)
  • Charge Time Limit: 24 hours (maintenance time: unlimited)
  • Maintain/Test Cycles: 30 min/30 min (alternating hourly)
  • Charge Retention Test: Range 10.1 - 13.3V GOOD (green) = battery voltage >13.3V
  • Input-Output Cable Length: 2m
  • Dimensions (LxWxH): 199 x 71 x 61mm
  • Weight: 740g
SKU: OC-0-UK
Guía del usuario de OptiMate 0.8A
Videos
OptiMate 0.8A Charger Overview
Cargar video: Features & installation of the OptiMate 0.8A lithium battery charger
