Ducati 848, 1098, 1198 Aim Solo 2 DL & Enchufe para registrador EVO4S & Reproducir cable
Choose Accessories
Ducati Motorcycle ECU Connection
The Ducati ECU Plug & Play Cable allows you to connect Aim Data Loggers, such as the Solo 2 DL, ECULog, XLog or EVO4S, to the Ducati-specific connector. The Ducati ECU Cable provides an easy plug & play connection to the motorcycle's ECU on one end, and uses a metal 712 screw-on binder connector with 7-pins on the other end, allowing ECU data to be logged.
Plug & Play Cable
The plug & play cable has been specifically designed for the following Ducati motorcycle models and years:
- Ducati 848 Base/EVO/EVO Corse – 2007-2013
- Ducati 1098 Base/S/S Tricolore/R – 2007-2009
- Ducati 1198 Base/S/S Corse/R Corse/SP – 2009-2011
Example Data Protocols
Example data protocols sampled can include RPM, gear, vehicle speed, throttle position and water and intake air temperatures. Refer to the user guide in the Downloads tab for a full protocol list.
Ducati Solo 2 DL Plug & Play Cable
