Dyn X Steering Wheel Mount
Take your sim racing setup to the next level with the Dyn X steering wheel mount. Engineered for maximum versatility, this mount allows you to integrate a wide range of steering wheel bases seamlessly with your Dyn X cockpit.
Steering Wheel Mount Configurations
Available in both side mount and tray mount configurations, the Dyn X steering wheel mount ensures broad compatibility across leading brands and models, giving you the freedom to race with the hardware you already own—or upgrade without limitations.
Built with precision and durability in mind, the Dyn X steering wheel mount not only enhances cockpit adaptability but also empowers you to personalise your rig exactly the way you want it. Whether you’re chasing peak realism or tailoring ergonomics to your style, the Dyn X steering wheel mount provides the stability, flexibility, and customisation options needed for an exceptional sim racing experience.
  • Steering Wheel Mount Material (All Mounts): Steel
  • Steering Wheel Mount Material Thickness (All Mounts): 6mm
  • Steering Wheel Slide (Forward/Back): 300mm
  • Steering Wheel Mounting Positions (Front & Side Mount): 6 (3 regular + 3 with mount inverted)
  • Steering Wheel Mount Degrees of Adjustment (Front & Side Mount): Position 1: 50°, Position 2: 47°, Position 3: 44°, Total: 80° (regular + inverted)
  • Steering Wheel Mount Height Adjustment (Front & Side Mount): 81mm (6 positions)
  • Steering Wheel Mounting Positions (Tray Mount): 4 (2 regular + 2 with mount inverted)
  • Steering Wheel Mount Degrees of Adjustment (Tray Mount): Position 1: 26°, Position 2: 24°, Total: 60° (regular + inverted)
  • Steering Wheel Mount Height Adjustment (Tray Mount): 140mm (4 positions)
  • Component 3: Dyn X - Steering Wheel Mounts - Side Mount
  • Component 4: Dyn X - Steering Wheel Mounts - Tray Mount
  • Side Mount - Supported Mounting Style: Side-mounted
  • Side Mount - Material: 6mm mild steel plate
  • Side Mount - Dimensions: 132.3 x 135.5 x 234.4mm
  • Side Mount - Degrees of Adjustment: Position 1: 50°, Position 2: 47°, Position 3: 44°, Total: 80° (regular + inverted)
  • Side Mount - Height Adjustment: 81mm (6 positions)
  • Tray Mount - Supported Mounting Style: Desk-mounted
  • Tray Mount - Material: 6mm mild steel plate
  • Tray Mount - Dimensions: 435.6 x 106.2m x 249.0mm
  • Tray Mount - Degrees of Adjustment: Position 1: 26°, Position 2: 24°, Total: 60° (regular + inverted)
  • Tray Mount - Height Adjustment: 140mm (4 positions)
  • Product Number: IXM-WM1-KS-NN-1 (Side Mount)
  • Product Number: IXM-WM1-KT-NN-1 (Tray Mount)
SKU: CM-ATM
Steering Mount User Guide
Steering Mount Tech Sheet
Videos
Dyn X Setup Overview
Cargar video: Features & capable adjustments with the Dyn X racing simulator
