Enlace Sensor de temperatura del aire de entrada (IATB) Bosch
Choose Accessories
Inlet Air Temperature Sensor
The Link inlet air temperature (IABT) sensor measures the temperature of the incoming air to the engine. This information is provided to the engine control module (ECU) to determine the correct amount of fuel needed for optimum performance and economy.
Why Choose the Link Inlet Air Temperature Sensor
The Link inlet air temperature sensor provides accurate monitoring of incoming air temperatures for optimal engine performance. It is supplied with a 2-way Bosch-style plug, complete with terminals and boot for straightforward wiring.
Aluminium and steel weld-in mounting bosses are available, offering secure and flexible installation options to suit a variety of applications.
Terminales de enchufe estilo Bosch de 2 vías
