Aim Interfaz de distribución de energía EPM32
Next-Generation Electrical Safety
The Aim Main Battery Switch (MBS) is a next-generation electrical safety cut-off system, specifically designed for the rigours of professional motorsport applications. Engineered to meet and exceed FIA, SFI and national motorsport regulations, it ensures instant and reliable shutdown of the vehicle’s electrical system in case of emergency or need.
Why Choose the Aim Main Battery Switch?
The Aim MBS is available in two versions (300A or 150A), covering the different needs of the market. Its primary goal is to ensure vehicle and driver safety by isolating and disconnecting the electrical system. The MBS's key features include:
- External controls
- Integrated IMU detects crashes or pre-programmed dangerous conditions
- External signal or CAN command triggers battery disconnection
- Total Power Isolation: Instantly disconnects the battery and electronic control circuits to prevent electrical fires and short circuits
- Programmable via USB or CAN
Main Battery Switch
