Kawasaki ZX-10R Aim Solo 2 DL & Enchufe para registrador EVO4S & Reproducir cable
Choose Accessories
Kawasaki ZX-10R
Kawasaki Motorcycle ECU Connection
The Kawasaki ECU Plug & Play Cable allows you to connect Aim Data Loggers, such as the Solo 2 DL, ECULog, XLog or EVO4S, to the Kawasaki-specific connector. The Kawasaki ECU Cable provides an easy plug & play connection to the motorcycle's ECU on one end, and uses a metal 712 screw-on binder connector with 7-pins on the other end, allowing ECU data to be logged.
Plug & Play Cable
The plug & play cable has been specifically designed for the following Kawasaki motorcycle models and years:
- Kawasaki Ninja ZX-10R MY2011 – 2011-2015
- Kawasaki Ninja ZX-10R MY2011 Racing Kit – 2011-2015
- Kawasaki Ninja ZX-10R MY2016 – 2016-2020
- Kawasaki Ninja ZX-10R MY2016 Racing Kit – 2016-2020
- Kawasaki Ninja ZX-10R MY2021 – From 2021
- Kawasaki Ninja ZX-10R MY2021 Racing Kit – From 2021
Example Data Protocols
Example data protocols sampled can include RPM, gear, vehicle speed, front wheel speed, rear wheel speed, brake and oil pressure, throttle position, low fuel level, traction control, map menu and many more. Refer to the user guide in the Downloads tab for a full protocol list.
Kawasaki Solo 2 DL Plug & Play Cable
