Mount Your System
The Kawasaki Motorcycle Bracket has been specifically designed to provide a simple and secure mounting solution for Aim Solo 2 and Solo 2 DL Lap Timers. The bracket is compatible with Kawasaki ZX-10R motorcycles from 2011 to 2020.
Why Choose the Aim Solo 2/2 DL Motorcycle Bracket
The Aim Solo 2/2 DL Motorcycle Bracket ensures your Solo 2 GPS Lap Timer can be securely mounted on your Kawasaki ZX-10R motorcycle. Supplied with all the necessary hardware, it provides a quick and stress-free installation, so you can accurately track and monitor your laps with ease.
Kawasaki ZX-10R Motorcycle
Plug & Play Cable
A separately sold plug & play cable is also available for the following Kawasaki motorcycle models:
  • Kawasaki Ninja ZX-10R
If you are unsure whether this bracket will fit your motorcycle, don't hesitate to contact our team.
  • For Kawasaki motorcycles only
  • Compatible with Ninja ZX-10R 2011-2020
  • Mounting bracket for the Solo 2 & Solo 2 DL Lap Timers
SKU: KAW-B
Part Number: X47KPFSOLO2KN
  • Soporte Kawasaki Solo 2/2 DL
  • x2 tornillos Allen de cabeza plana M4x10mm
  • Bolt icon
    x2 tornillos Allen M6x12mm
  • x2 Arandelas Dentadas
Kawasaki User Guide
