Enlace Sensor de mapa de 5 bares (MAP5)
Link 5 Bar MAP Sensor
The Link 5 bar MAP Variohm Eurosensor measures absolute pressures up to 5 bar, making it ideal for turbocharged or supercharged applications running up to 4.0 bar (58 PSI) of boost.
Why Choose the Link 5 Bar MAP Sensor
The Link 5 bar MAP Variohm Eurosensor can be mounted via a weld-on bung, tapped hole, or remotely using a barb, and is supplied with a plug and pins for straightforward installation. When using Link G4, G4+, or G4X ECUs, select ‘Variohm 5 Bar’ as the MAP sensor type in PC Link for proper calibration.
5 Bar MAP Sensor
3-Pin Connector Kit
