Ethanol Content Sensor
The ethanol content sensor (ECS) measures the ratio of ethanol to petrol in a flex-fuel vehicle. This sensor also measures fuel temperature and is compatible with all current Link wire-in and plug-in ECUs.
The Link ethanol content sensor uses 1 digital input on the ECU. The sensor is fitted to the vehicle’s fuel return line anywhere between the fuel pressure regulator and the fuel tank. This product includes AN-6 fittings and a plug and pin kit.
The pinout is indicated on the sensor itself (from left to right, looking into the connector on the sensor) as:
  • Vcc (+12V supply)
  • GND (ground)
  • Vout (digital signal out)
SKU: ECS
  • Link ECS ethanol content sensor for fuel system monitoring
    Sensor de contenido de etanol
  • Accesorios AN-6
    Clavijas del enchufe ECS &
  • Link ECS ethanol content sensor for fuel system monitoring, shown as a compact automotive sensor device
    Tornillos ECS & Arandelas
Descargas de enlace de PC
