Link G4 Knock Link Link Kit - incluye sensor de knock y telar
Link Knock Sensor
The G4 KnockLink's microprocessor continuously scans the knock signal and warns of any knock occurring. The engine's RPM and load are automatically 3D profiled by the KnockLink, continuously storing and dynamically adjusting this noise profile map while looking for the particular knock frequency.
Why Choose the Link G4 KnockLink Kit
The G4 KnockLink kit comes with a visual warning light and a knock sensor with a loom. It is the only detonation warning device on the market that requires no setup, while other systems require time-consuming gain, frequency, and noise settings to be adjusted. Without proper knock listening tools, this can prove difficult, if not impossible. The KnockLink requires none of this, just wire in and start the engine.
LED Modes
The colour of the LED represents 4 different modes:
- Dim Blue: KnockLink is powered, waiting for the engine to be started.
- Flashing Blue: KnockLink has detected the engine has started and is now calibrating.
- Dim Green: KnockLink is adapting to the engine's noise profile and listening for knock.
- Flashing Red: KnockLink has detected knock. Avoid large throttle openings and seek professional advice.
Enlace de golpe G4
Sensor de detonación & Telar
