Link G4+ Kurofune WireIn ECU
SKU: G4K
- Precio regular
- £1,225.00
- Precio regular
- Precio de venta
- £1,225.00
- Precio unitario
- por
+ IVA (Solo Reino Unido)
The Kurofune is Link’s first G4+ ECU built to run off adapter looms.
The Kurofune is a direct replacement for a common aftermarket Japanese ECU, but with significantly more functionality and user configurability than the ECU, it replaces. Sharing the same connector footprint and pinout to this ECU means there is already a host of aftermarket adapter looms that will allow the Kurofune to plug straight in.
Special hardware features included in the Kurofune, such as differential trigger inputs and analogue outputs which can be used to emulate a MAF or oxygen sensor, make it Link's most suitable ECU for “piggyback” type installs.
Inputs
10 x Digital Inputs
3 x Temperature Inputs
9 x Analog Inputs
2 x Differential Trigger Inputs
2 x Knock Inputs
Outputs
8 x Injection Drives
8 x Ignition Drivers
10 x Auxiliary Outputs
4 x Analog Outputs
+5V Sensor Power Supply
Communications
1x CAN bus
1x USB tuning connection
Physical
Dimensions: 140mm(L) x 150mm(W) x 33mm(H) (without looms)
Mass: 300 grams
Advanced features not found on the Storm:
30 general-purpose tables (up from 20)
All Motorsport features including full gear shift control, anti-lag, traction and launch control.
Link G4+ Kurofune ECU
- G4+ Kurofune ECU
- USB Tuning Cable
The Kurofune is Link’s first G4+ ECU built to run off adapter looms.The Kurofune is a direct replacement for a common aftermarket Japanese ECU, but with significantly more functionality and user configurability than the ECU, it replaces. Sharing the same connector footprint and pinout to this ECU means there is already a host of aftermarket adapter looms that will allow the Kurofune to plug straight in.
Inputs
10 x Digital Inputs3 x Temperature Inputs
9 x Analog Inputs
2 x Knock Inputs
Outputs
8 x Injection Drives8 x Ignition Drivers
4 x Analog Outputs
Communications
1x CAN bus1x USB tuning connection
Physical
Dimensions: 140mm(L) x 150mm(W) x 33mm(H) (without looms)Mass: 300 grams
30 general-purpose tables (up from 20)All Motorsport features including full gear shift control, anti-lag, traction and launch control.
- G4+ Kurofune ECU
- USB Tuning Cable
