Link HondaLink PlugIn ECU
The Link HondaLink - HC20X is a G4X PlugIn ECU, offering the latest in engine management technology.
Please Note: This PlugIn ECU features a new 4-pin powered CAN connector and cannot use the old CANPCB cable for CAN connection. Use the CANJST4 (Code 101-0198) cable for connecting CAN devices. This new 4-pin port and cable also provide a protected 12V power supply and ground for powering the CAN devices. The power supply is protected by a self-resetting fuse rated at 3A continuous.
Why Choose the HondaLink PlugIn ECU
The Link HondaLink - HC20X PlugIn ECU fits inside the factory OEM enclosure. Installation is a breeze, with no alteration of the factory wiring loom required for the manual transmission models listed below:
  • Honda Integra Type R DC5 2002-2004 with K20A/K20A2/K20A3 Engine
  • Acura RSX 2002-2004 with K20A/K20A2/K20A3 Engine
  • Honda Civic Type R EP3 2001-2005 with K20A Engine
  • Honda Civic Si/SiR 2001-2005 with K20A3
  • Honda Civic DX/LX/HX 2001-2005 with D17A1/A2/A3 Engine
  • Honda CR-V 2002-2004 with K24A1 Engine
  • Please check that your connector matches the header in the listed photo before purchasing.
  • The PluIn ECU includes an onboard 7 bar MAP sensor.
Suitable Applications
The HC20X PlugIn ECU works for manual transmissions only.
PlugIn Key Features
  • Up to 6D fuel and ignition mapping
  • Precision closed-loop cam control (four cam, independent control)
  • Sequential fuel delivery
  • Digital triggering, all OEM patterns
  • OEM idle hardware supported
  • 5D boost control with three switchable tables
  • Motorsport features - antilag, launch, flat shift
  • Continuous barometric correction (on board)
  • CAN port
  • QuickTune - automated fuel tuning
  • Individual cylinder correction
  • USB tuning cable included
  • Stats recording into on-board memory
  • Gear compensations for spark, boost and fuel
  • Real time selectable dual fuel, ignition and boost maps
  • Sync and crank sensors can be a combination of Hall effect, variable reluctance or optical
  • Boost control referenced to gear, speed or throttle position
  • 512 mega bytes data logging memory
  • Staged injection
  • Knock with "windowing"
I/O Expansion Options
Expansion Connector 1
Pin 1: Ground (signal)
Pin 2: +14 out
Pin 3: An Temp 4
Pin 4: An Temp 3
Pin 5: DI10
Pin 6: DI9
Pin 7: IGN3
Pin 8: IGN4
E-Throttle Connector
Pin 2: +5V out
Pin 3: An Volt 12
Pin 4: An Volt 11
Pin 5: An Volt 10
Pin 6: An Volt 9
Pin 7: Aux 10
Pin 8: Aux 9
The PlugIn ECU is capable of the following features, if the car it is being used in will support them.
Engine Configurations
  • 1-12 Cylinder Distributed
  • 2-12 Cylinder Wasted Spark
  • 1-8 Cylinder Direct Spark
  • Odd Fire Engines
  • 2-Stroke, 4 Stroke and Rotary Engines
  • Configurable Firing Order
  • Configurable TDC Points (for odd fire)
Inputs/Outputs
  • 8 x High Current Injector Drives (suits high impedance injectors)
  • 8 x Ignition Channels
  • 8 x Auxiliary Outputs (All PWM capable). Aux5-8 can control Stepper Motors and drive High or Low
  • 11 Digital Inputs (All capable of reading frequencies up to 10kHz)
  • +5V Out
  • +8V Out
  • 4 Temperature Inputs (Configurable pull-ups on ANT1&2)
  • 12 x 0-5V Analogue Inputs
  • 2 x Trigger Inputs (Reluctor, Optical or Hall Sensors)
  • On Board Baro
  • 3 Axis Accelerometer
Fuelling Adjustments
  • Traditional, Modelled and Modelled Multi-Fuel Equations
  • Single-Point Group, Multi-Point Group, Sequential, Semi-Sequential, Group Staged, Sequential Staged and Sequential/Multi Point Group Staged injection modes
  • Asynchronous injection (can add more fuel after initial injection if conditions change)
  • Quick tune (automated fuel tuning)
  • Up to 440 Zone Fuel Table with configurable load and RPM centres. Configurable X and Y Axis Parameters
  • Multiple Fuel Tables
  • Up to 6D Fuel Mapping (3D Fuel Table + 3x3D Overlay trim tables)
  • Injection Rate Control for Group Injection Modes
  • Master Enrichment for Traditional Fuel tuning
  • Pre-Crank Prime
  • First Crank Prime
  • Crank Enrichment
  • Post Start Enrichment
  • Warm Up Enrichment
  • Acceleration Enrichment
  • IAT Fuel Correction
  • Injector Deadtime Compensation
  • Injector Short Pulse Width Compensation
  • Injector Timing Control with Beginning, Middle or End Injection Definable
  • AFR Table Correction
  • Dual Closed Loop Lambda
  • Individual Cylinder Fuel Trims
  • Overrun Fuel Cut
  • Idle Load Trims
  • Fuel Temperature Correction
  • Barometric pressure compensation
  • Injector test function
Ignition Adjustments
  • Distributor, Twin Distributor, Wasted Spark, Direct Spark, Rotary leading Wasted and Rotary
  • Leading Direct Ignition Modes
  • Up to 440 Zone Ignition Table with configurable load and RPM centres. Configurable X and Y Axis Parameters
  • Configurable Maximum Advance
  • Configurable Spark Duration
  • Configurable Spark Edge
  • Dwell Time Table with configurable X and Y Axis Parameters
  • Multiple Ignition Tables
  • Up to 6D Ignition Mapping (3D Ignition Table + 3x3D Overlay Trim Tables)
  • Individual Cylinder Ignition Trim
  • IAT Trim
  • Voltage Correction
  • ECT Trim
  • OEM Compatibility
  • CDI Compatibility
  • Transient ignition retard
  • Adjustable ignition delay compensation
  • Ignition test function
  • Idle ignition control
Limits
  • Engine Temperature Dependent Progressive Limiting
  • Dual Vehicle Speed Limits
  • System Voltage Limit
  • User Configurable RPM Limits based on external input
  • MAP Limit with dual tables
  • Optional hard cut
  • Progressive cut control
  • Selectable fuel or ignition limiting
  • Ignition trim and configurable trim decay
  • Adjustable control range
  • Selectable cut effect (adaptive or constant)
Auxiliary Output Options
  • Each Output is independently configurable
  • Unused ignition and Fuel outputs available as auxiliary outputs
  • General Purpose Outputs
  • General Purpose PWM Outputs
  • Fuel Pump Control
  • Fuel Pump Speed Control
  • Engine Fan Control
  • Air Con Clutch Control
  • Air Con Fan Control
  • Intercooler Spray Control
  • Tacho Control
  • Speedo Control
  • Check Engine Light
  • Purge Solenoid
  • Oxygen Sensor Heater
  • Switched Cam Solenoid Control
  • ECU Hold Power Control
  • Shift Light Control
  • Starter Control
  • VVT Cam Solenoid
  • Boost Control Solenoid
  • Test functions for each output
  • Closed-loop Stepper Control & Rotary Oil Pump Control
  • Idle Speed Soloenoid
  • Idle Speed Stepper
  • Internal EThrottle Controller
  • External EThrottle
Digital Inputs
  • Each channel is independently configurable with pull-up resistors and active state control
  • All digital inputs are capable of reading frequencies of up to 10kHz
  • Duty Cycle measuring on all digital inputs
  • Turbo speed
  • Ethanol Sensor Control
  • Wheel Speed Detection on all digital inputs with additional general-purpose speed inputs
  • Anti-Theft control through digital inputs, over CAN or both
  • General Purpose switches, speeds, RPMS and frequencies
  • Large variety of input types
Analogue Inputs
  • Each input independently configurable with preset or custom calibrations and configurable fault conditions
  • Built-in 3-axis accelerometer
  • Built-in Barometric Pressure Sensor
  • Large variety of analogue input functions
  • General Purpose Temperatures, Pressures, Rotary Switches and more
  • Analogue Inputs can also be used as Digital Inputs
  • Large number of built-in calibrations
  • Ten Calibration Tables and 3 Linear Calibrations for when a custom calibration is required
Triggering
  • Digital Trigger Decoding
  • Reluctor, Optical Proximity or Hall Sensors
  • Programmable filtering and arming thresholds
  • Configurable trigger patterns or preset triggering options
  • Supports nearly all OEM trigger patterns and custom trigger arrangements
Programmable Math Processing
  • Eight individually controllable math channels with up to four parameters in each
  • Math channels can be used as table axes and as digital or analogue inputs
Motorsport Features
  • Anti Lag
  • Launch control
  • Gear Shift Control (Digital Inputs, Gear Lever Force or Gear Barrel Position)
  • Traction control
Anti-Lag System
  • Dual 3D Fuel enrichment, Ignition cut and Ignition retard Tables
  • Optional Cyclic idle (normal and cool-down)
  • Optional 3D Idle controller Override Tables (one for Antilag and one for Cyclic Idle)
  • Lockout conditions based on engine speed and throttle position with hysteresis
Launch Control
  • Single RPM, 3D RPM Table or Latched (RPM when button pressed) Launch modes
  • Vehicle speed controlled
  • Ignition Trim with optional 3D table and relative or absolute ignition angle options
  • Optional 3D Fuel Trim table
Gear Shift Control
  • Digital input (clutch switch), gear lever force (sequential gearbox), gear lever force (H pattern gearbox), and gear barrel position sensor input options
  • Timed or controlled modes
  • Adjustable progressive cut levels
  • Power re-introduction control
  • Ignition retard control
  • Fuel enrichment control
  • Cut duration based on gear
Traction Control
  • Disable switch
  • Various Lockout conditions
  • Multiple 3D slip Threshold tables
  • Traction Control - controlled tyre slip to improve vehicle safety and driveability
  • Uses an advanced Torque Management system to reduce engine torque
Idle Control
  • Solenoid, Stepper or EThrottle Control
  • Open or Closed loop actuator control and Closed loop Ignition control available
  • Large variety of position offsets for open loop and additional target offsets for closed loop actuator control
  • Specific start-up offsets and hold times
  • Dashpot functionality to smooth re-entry into idle and prevent undershoot
Electronic Throttle Control
  • Has an internal EThrottle Controller and supports external controllers
  • Multiple 3D target tables
Boost Control
  • Open or Closed Loop Boost Control
  • Multiple Target and Base Position Tables
  • Multiple Trim tables
  • Boost by Gear control
Knock Control
  • 2 Built in Knock inputs
  • Fuel Enrichment and Ignition Retard functionality
  • Adjustable frequency filter
  • Adjustable gain (per cylinder)
  • Individual cylinder detection
  • Individual cylinder ignition retard and fuel enrich
  • Adjustable detection angle (start/end)
  • Noise threshold table (3D)
  • Adjustable ignition retard and fuel enrich sensitivity
  • Configurable ignition reintroduction and fuel enrich decay
Variable Valve Timing Control
  • Up to 4 cams independent control
  • Supports many OEM applications
  • Closed loop control
  • Multiple 3D Cam angle target tables
  • Optional advanced PID control settings for advanced tuners
  • Automatic function for calibrating cam angles
Chassis and Body
  • AC Control - Basic and Advanced modes available
  • Anti-Theft - Via Digital Input, CAN or both
  • Speed based cruise control (EThrottle only)
  • Gear Detection - CAN, RPM/Speed or Analogue Position Sensor
  • Individual wheel speed sources with the ability to specify Driving and Non-Driving wheel speed sources
  • Starter control - Multiple options available from very basic to touch to start.
Torque Management
Logging
  • 512 Megabytes of Datalogging
  • Up to 250 ECU Logging channels
  • Up to 1kHz per channel with a maximum total sample rate of 100kSamples/s when using ECU Logging
  • Unlimited channels when using PCLink logging
Communications
  • Tuning Port USB on board
  • Two CAN buses
  • Custom CAN configuration allowing tuners and end users to add support for new CAN devices
Processing
  • 150 MHz Specialised Engine Management Microprocessor
  • Ignition control to 0.1 degree, fuel to 0.01 ms
  • 32 Bit Floating Point Calculation
  • 12 Bit ADC Resolution
  • 20000+ RPM
  • 4Gb Non Volatile Flash
Environment
  • Internal Temperature Range -10 - 85°C
  • Ambient Temperature Range -30 - 90°C
  • Voltage 8 - 22V
  • Operating Current 200mA
  • Electrical protection on all inputs and outputs
  • Onboard Barometric Pressure Sensor
SKU: HC20X
Honda PlugIn ECU Manual
G4X PlugIn ECU Tech Spec
Descargas de enlace de PC
