The UK’s Leading Live Streaming Device
Take your live streaming to the next level with LiveU Solo PRO – the professional-grade, portable video encoder trusted by motorsport creators, sports teams, videographers and broadcasters worldwide.
Whether you’re transmitting SmartyCam 3 GP, GP Pro, or Dual footage straight to the pit, or streaming live to YouTube, Facebook, Instagram, Twitch and beyond, the LiveU Solo PRO delivers broadcast-quality 4K video with the reliability and freedom you need.
Why Choose the LiveU Solo PRO
Get rock-solid performance even in challenging network conditions. Enjoy up to 20Mbps streaming and optional HEVC/H.265 encoding for maximum quality at minimum bandwidth. Available in HDMI or SDI/HDMI versions, the LiveU Solo PRO ensures your live streams look as good as your vision.
Designed for Creators
Join thousands already using the Solo Creator Universe (SCU):
  • IRL Streamers – Go live anywhere, wire-free and stress-free. Add Solo Connect PRO, your creativity and a camera – then just go!
  • Production Houses – Stream live events from anywhere with IP-video over bonded 4G/5G, no cables or venue networks required.
  • Sports Teams – Bring fans closer with easy-to-use, budget-friendly, broadcast-quality live streams.
  • Educational Institutions – From sports coverage to media training, the LiveU Solo PRO offers primetime results in a cost-effective package.
  • Videographers – Trust award-winning tech with HEVC, 4K, LRT™, long battery life and lightweight mobility so you can focus on storytelling.
Future-Proof Your Streaming
With the next-gen Solo PRO encoder, you can stream to any leading social platform or website. Simply connect your camera or switcher, log in via the web-based Solo Portal, select your destination, and go live.
Solo Creator Universe Services & Accessories
  • LRT™ Bonding Technology – Adaptive bitrate, bonded connections, and unmatched stability. Available monthly or annually.
  • Solo PRO Connect Kits – Complete plug-and-play packages with modems, data plans, and LRT™ included (two or four modem options).
  • Stream Tools – Multi-destination streaming, stream fallback, and logo watermark for enhanced brand presence.
  • Solo Belt Pack – Comfortable, practical, and designed for streaming on-the-go. Includes Y-cables, HDMI pigtail cable and space for modems/routers.
Trusted Worldwide
The LiveU Solo PRO is used by global broadcasters and streaming partners including:
Facebook, YouTube, Twitch, Vimeo, Twitter/X, Amazon Live, Dacast, Streann, Switchboard, Ustream, Grabyo, LinkedIn, Restream, Jstream
Stream without limits – wherever the action takes you.
  • Video Resolutions: 4Kp60/59.94/50/25/30/29.97/24, 1080p50/60/25/30/24, 1080i50/60, 720p50/60, PAL, NTSC
  • Video Interfaces: 12G/3G/HD/SD-SDI and HDMI 2.0
  • Video Encoder: H.265/HEVC, H.264
  • Audio Encoder Supported Bitrates: 96/128/256Kbps (AAC-LC)
  • Portability: Professional-grade cross-shoulder pack and belt pack options
  • Simultaneous Bonding: Up to 6 network links: 4 x external cellular modems (4G/5G), WiFi and Ethernet
  • Power Sources: 3 hours internal battery, USB-C power input, support for different types of USB-C power sources with a minimum of 45-watt power delivery
  • Local Control: Full monitoring and control using a local 2.2” display and a user-friendly rotating jog
  • Remote Control: Full web-based remote control from smartphones, laptops, tablets or any web browser
  • Display Information: Video preview; per network cellular connectivity status, incl. throughput, network delay etc
  • Resienscy & Quality: Enabled by LiveU Reliable Transport (LRT™), featuring proprietary algorithms
  • Interfaces: 2 x USB 2.0, RJ-45 Ethernet, USB-C (for power only)
  • Wireless Interfaces: WiFi 802.11 a,b,g,n,ac support with internal MIMO antennas
  • Dimentions: 112.5mm x 188mm x 54.5mm (W x H x D)
  • Weight: 912g HDMI configuration, 936g SDI configuration
  • Temperature: Operating: -5°C to +45°C
  • CDNs: Facebook, YouTube, Twitch, Vimeo and RTMP/S and more
  • LiveU Solo PRO SDI  4/5G Live Video Streamer - AimShop.com
    LiveU Video/Audio Encoder
  • 2x Angled USB 2.0 Type A Cable
  • Cable icon
    HDMI Female - HDMI Male Cable
  • HDMI Voltage Clip
  • Cable icon
    UK, EU & US Power cables
