MV Agusta F3 675, F3 800, F4 1000 AIM Solo 2 DL y EVO4S Logger Plug & Play Cable
MV Agusta Motorcycle ECU Connection
The MV Agusta ECU Plug & Play Cable allows you to connect Aim Data Loggers, such as the Solo 2 DL, ECULog, XLog or EVO4S, to the MV Agusta-specific connector. The MV Agusta ECU Cable provides an easy plug & play connection to the motorcycle's ECU on one end, and uses a metal 712 screw-on binder connector with 7-pins on the other end, allowing ECU data to be logged.
Plug & Play Cable
The plug & play cable has been specifically designed for the following MV Agusta motorcycle models and years:
- MV Agusta F3 675 – From 2012
- MV Agusta F3 800 – From 2012
- MV Agusta F4 1000 – 2013-2018
Example Data Protocols
Example data protocols sampled can include RPM, gear, vehicle speed, throttle position, traction control, manifold air pressure and many more. Refer to the user guide in the Downloads tab for a full protocol list.
MV Agusta Solo 2 DL Plug & Play Cable
