MyChron 6 mini unidad USB 16GB
USB Memory Drive
The Aim 16GB Mini USB Drive is a compact memory drive that can be connected via USB Type-C to the MyChron 6 Lap Timer range, as well as ECULog and XLog Data Loggers.
Why Choose the Aim 16GB Mini USB Drive
The Aim 16GB Mini USB Drive is a compact and reliable memory drive that can be plugged directly into your data logger to transfer data from the logger to the drive. Compatible data loggers include the MyChron 6 series, ECULog, XLog and CANKey.
Providing an additional 16GB of data logging memory, the drive can be connected directly to any device with a USB Type-C connection, or to a PC using the included USB Type-A adaptor, to easily download the files. Once you have downloaded your files, the drive and USB-C adaptor can be stored in the included aluminium case with protective polyurethane foam housing to keep everything safe from knocks, dust, and moisture when not in use, maintaining the longevity and reliability of your data storage equipment.
16GB Mini USB Drive & Adaptor
