Customise Your Steering Wheel
With over 100 stickers, including 12 rotary options, there are various motorsport functions to choose from to customise your Steering Wheel Plate. The stickers have been designed to specifically surround the buttons allowing a perfect fit on your button plate.
Stickers on 10 Channel Steering Wheel Plate
10 Channel Sticker Sheets
We offer an extensive range of waterproof and fade-resistant 10 Channel Sticker Sheets designed for our Wireless Steering Wheel Plate. 3 different sticker sheets come with this kit, each with different colour options, allowing you to apply stickers to the more essential buttons you want to stand out.
Please Note: The example shown is to show how the stickers could look on a Steering Wheel Plate; the plate is sold separately. We also sell 4 & 8 Channel Sticker Sheets to suit any setup.
  • Rotary stickers:
  • 12 waterproof, 180 microns, vinyl stickers
  • Low initial tack with high ultimate adhesion
  • Overall sheet dimensions 148mm x 105mm
  • 6 larger stickers have a 28mm outer diameter, 10mm inner diameter
  • 6 smaller stickers have a 20mm outer diameter, 10mm inner diameter
  • Motorsport stickers:
  • 120 waterproof, 180 microns, vinyl stickers
  • Low initial tack with high ultimate adhesive
  • Overall sheet dimensions 310mm x 220mm
  • Circle stickers have a 12mm internal diameter hole - apply before soldering
  • Sausage stickers follow a 12mm diameter curve and can be retro-fitted where the switches are already soldered
SKU: RBI-SS10
  • 10 Channel Sticker Sheets for Wireless Steering Wheel Plate - AimShop.com
    Button Sticker Sheet No.1
    Button Sticker Sheet No.2
    Rotary Switches Sticker Sheet
