Aim Registrador de datos de carreras ECULog
Choose Accessories
Compact Data Logger
The Aim ECULog is a compact, lightweight, and waterproof data logger designed to record essential performance data directly from your vehicle’s ECU. With its ultra-small size, it’s ideal for motorcycles, karts, or vehicles with limited installation space.
Why Choose the ECULog Data Logger
The ECULog is designed for those who want simple but powerful ECU data recording in the most compact form. With its ability to integrate with Aim expansions, GPS modules, and cameras, the ECULog transforms into a versatile performance monitoring system.
ECULog Features
The compact data logger calculates:
- Lap times
- Sector times
- Vehicle position and speed
- 3D acceleration and gyro
- ECU data via CAN, K-Line or RS232 connections.
(You can select the protocol of your car/bike among thousands of pre-defined protocols, or easily develop your own). - Digital RPM input from the primary of the coil (150-400V) or from a square wave (8-50V) when no ECU connection is available.
In addition, the ECULog features a second CAN for connecting an external device or Aim Expansion, meaning you can add a Lambda Controller, analogue inputs, and a professional motorsport camera for enhanced functionalities.
GPS & Inertial Platform
While the ECULog itself focuses on ECU data, it integrates seamlessly with expansions for broader functionality:
- GPS09 Module (optional): Adds 25Hz GPS data for lap timing, track position, and speed.
- Inertial Data: Expandable to include 3D accelerations and gyro data via the Aim ecosystem.
ECULog Connectivity
The ECULog ensures flexible data acquisition for a wide range of applications:
- ECU Connection: Compatible with thousands of predefined CAN, K-Line, or RS232 protocols.
- Expansions: Connect to Aim modules such as ACC3 (analogue inputs), LCU-One Lambda controller, or SmartyCam 3.
- Storage: 4GB internal memory plus a removable USB-C key for easy transfer.
Compact, Durable Design
Measuring just 61 × 44 × 27mm, the ECULog is the smallest logger in the Aim lineup. Its IP65-rated housing protects against dust and water spray, making it suitable for both motorcycles and motorsport applications where durability is crucial.
Analyse with Race Studio 3
All data logged by the ECULog can be downloaded wirelessly or via USB-C, then reviewed in Aim’s professional Race Studio 3 software.
ECULog Data Logger is built to scale with your needs:
- ACC3 Analogue Input Module: Add pressure, temperature, or suspension sensors.
- LCU-One Lambda Controller: Log air/fuel ratios and exhaust data for engine tuning.
- SmartyCam: Overlay ECU and expansion data directly onto HD video.
ECULog
Mini USB Drive 16GB
Your Chosen Harness
USB A – USB C Cable
| Specs |
ECULog Data Logger
XLog Data Logger
EVO6 Data Logger
EVO6L Data Logger
Which products are compatible with the Aim ECULog Data Logger?
The ECULog Data Logger is designed to work within the Aim ecosystem to enhance performance monitoring. Compatible Aim products include the SmartyCam range, GS-Dash, Data Hubs, ACC3 and various sensors.
How does the Aim ECULog Data Logger work with the SmartyCam 3?
The ECULog logs all the data, such as RPM and temperature, onto its internal memory. After the SmartyCam is connected via a CAN connection, the ECULog transmits according to the SmartyCam Stream onto the EXP port, and the SmartyCam receives the data in real time.
When you record a session, data is logged, and the SmartyCam overlays this directly onto the video footage. This means that you get lap times, speed and other data as part of your track recordings.
Is the Aim ECULog Racing Data Logger good for karting?
The ECULog is designed to log data directly from an ECU via CAN, K-Line or RS232, making it an ideal product for vehicles with a compatible electronic control unit. If you are running a custom or higher-end kart with an ECU and want to log all available engine parameters, the ECULog is ideal. If your kart doesn't have a compatible ECU, the MyChron 6 range is the better option as it does not require external power to work and is specifically designed for karting.
