Aim Registrador de datos de carreras EVO5
Free Shipping Above £100
Professional Data Logger
Take your data acquisition to the next level with the brand-new Aim EVO6 Data Logger, a professional-grade system built for racers. Absolute precision and total control. Designed for high-performance motorsport applications, the EVO6 delivers advanced data logging, integrated GPS, and inertial tracking in one compact, rugged unit. This isn’t just data; it’s your competitive edge captured in real time.
Why Choose the EVO6 Racing Data Logger
The EVO6 Racing Data Logger is engineered for flexibility and scalability, making it the perfect core of any modern data system. Whether paired with displays, power distribution modules, or additional sensors, the EVO6 integrates seamlessly into your setup. Its ability to synchronise GPS, IMU and vehicle data ensures you get a complete, accurate picture of every lap—helping you analyse performance with confidence and make smarter decisions on track.
If you’re serious about extracting every ounce of performance, the Aim EVO6 Data Logger is the upgrade that puts you ahead. More data, more control, more speed.
EVO6 Features
The EVO6 features 8 fully configurable analogue inputs compatible with a wide range of sensors, including temperature, pressure, and more, along with 4 speed inputs and coil RPM acquisition for precise monitoring of vehicle speed and engine performance. An integrated 25Hz GPS module delivers highly accurate lap timing and track positioning, while the 100Hz 3-axis IMU (±5G) captures acceleration, braking, and cornering forces in detail for deeper insight into vehicle dynamics and driver input.
Built-in Wi-Fi and Bluetooth enable fast, cable-free configuration and data download, while expandable SD card storage of up to 128GB allows longer recording sessions without compromise. All of this is housed within a compact anodised aluminium enclosure designed to withstand the demands of extreme racing environments.
A Range of Data Sources
The EVO6 can sample all the data you need from a wide range of sources, including your vehicle ECU via CAN, RS232 or K-line, as well as from the internal accelerometers and gyro, and the GPS09 receiver included in all available kits. Additional data can also be acquired through analogue and digital inputs, external expansions, and predefined math channels.
Sensors can be connected to 8 configurable analogue channels, the RPM input, and up to 4-wheel speed inputs, making the EVO6 ideal for advanced vehicle data acquisition and analysis.
Connection Type
The EVO6 features two multi-channel motorsport connectors designed for simple and reliable installation. A high-quality wiring harness manages all connections through a 37-pin connector for main functions such as power, CAN, and the Aim CAN network, along with a 22-pin connector dedicated to additional functions, including CAN2, digital outputs, and more.
Digital & CAN Outputs
The EVO6 Data Logger features two low-side digital outputs (switch to ground), which can be configured to automatically switch external systems on or off based on the value of analogue or digital inputs. This allows automatic control of devices such as additional lights, cooling fans, circulation pumps, and other accessories when specific conditions or events occur.
The EVO6 also includes CAN Output functionality, allowing messages to be sent directly to an existing CAN network to expand vehicle monitoring and control capabilities.
Sensor Compatibility
Sensors can be connected to the EVO6 Data Logger via:
- 8 analogue channels with configurable inputs or thermocouple inputs, with a max frequency of 1,000Hz each, used to sample data coming from temperature, pressure, suspension and other sensors.
- 4 speed inputs, which allow you to monitor the different wheels' behaviours.
- 1 RPM input, which manages square wave signals transmitted by the ECU, or pulse signals picked from the coil command (low voltage).
EVO6
Chosen GPS Module
37-Pin Harness
USB to 719 Adaptor
Mini USB-USB Cable
| Specs |
EVO6 Data Logger
EVO6L Data Logger
ECULog Data Logger
XLog Data Logger
