Upgrade your riding setup with one of the best motorcycle lap timers in the industry — the Solo 2 DL GPS lap timer. Display instant speed, timing splits, live data and predictive lap times on a high-contrast display with an accuracy of up to two-hundredths of a second.
Why Choose the Motorcycle Solo 2 DL
Building on the features of the Aim Solo 2 model, the Solo 2 DL motorcycle lap timer connects directly to your bike’s ECU to record vital engine data, without the need for complex wiring. Compatible with a wide range of motorsport applications and bike ECUs, the Solo 2 DL is a versatile tool for helping motorsport professionals monitor and improve their performance in any motorsport discipline.
Cargar video: Solo 2 DL on Ducati motorcycle
Plug & Play Compatibility
This Solo 2 DL Kit comes with a cable to connect the Solo 2 DL to your bike, relaying all vital ECU information. The cable is specific to your bike model. Plug & play is currently available for the following bike models:
  • Aprilia RSV4 RR/RF, 1100, TUONO V4
  • Aprilia RSV4 RR/RF, 1100, TUONO V4 RR
  • BMW S1000RR, S1000RR HP4 (2009 -2019)
  • Ducati Panigale, 899, 959, 1199, 1199R, 1299 & V4 (2012 -2020)
  • Ducati 848, 1098 & 1198 (2007 - 2013)
  • Euro 5 Models (All Manufacturers)
  • Kawasaki ZX-10R (From 2011)
  • MV Agusta F3 675, 800 & F4 (From 2012)
  • Suzuki GSX-R 600, 750, 1000 (2001 -2019)
  • Yamaha YZF-R1/R1M (FROM 2015) & YZF-R6 (From 2017)
  • Yamaha YZF-R1 (2004 - 2008) & YZF-R6 (2006 - 2016) - YEC Included
  • Yamaha YZF-R1 (2009-2014) - YEC Included
  • Yamaha YZF-R6 (2004 - 2005) - YEC Included
Please select your model before adding the Solo 2 DL Plug & Play Kit to your cart.
Solo 2 DL is compatible with Suzuki, Aprilia, BMW, MV Augusta, Triumph, Yamaha, Honda and Ducati motorcycles
The Solo 2 DL motorcycle lap timer has a sharp, high-contrast display which helps riders easily identify the data displayed on screen, as well as 8 different backlight colours.
Thousands of pre-loaded worldwide track maps are available, the bike lap timer automatically recognises your position on the track as soon as it's switched on. Once you start to ride, it automatically recognises the start line coordinates of the track and starts sampling lap times every time you ride past.
The Solo 2 DL allows you to create a new temporary or permanent track layout too. Even if there is no track already, the device will create one for you.
Inertial Platform
One of the many reasons that the Aim Solo 2 lap timer is regarded as one of the best GPS lap timers in the motorsport industry is due to its easy configuration and integration with Race Studio 3 software.
Mounting Options
  • Display: Graphical LCD
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
  • Pushbuttons: Metallic
  • Solo 2 DL
  • Cable icon
    Power Cable with AC Adapter
  • Cable icon
    Your Chosen Connection Cable
Solo 2 DL User Guide
Solo 2 DL Tech Sheet
Videos
Overview
Cargar video: An in-depth review of the main features and functions of the Aim Solo 2 DL motorcycle lap timer.
What is the best track day lap timer?
The Aim Solo 2 DL is a high-precision, 25Hz GPS lap timer. It connects directly to your motorcycle’s ECU to provide detailed performance data such as speed, RPM, throttle position and more. It provides accurate lap times, split times and predictive timing, with advanced data logging capabilities, making it one of the best compact data logging lap timers with an integrated display for track days.
How does the Aim Solo 2 DL motorcycle lap timer work?
The Aim Solo 2 DL is a GPS lap timer that allows you to analyse instant speed, timing splits, live data and predictive, theoretical and delta times. It connects directly to the motorcycle's ECU and multiple satellite constellations (GPS and GLONASS), providing performance data in real time.
The Aim Solo 2 DL uses a range of different technologies to enhance user experience. It has a 25Hz GPS receiver for precise lap timings and position markers, a 100Hz 6-axis inertial platform that provides data on roll, pitch and yaw. It also has integrated data logging capabilities via CAN bus, for advanced and comprehensive data collection.
How do the standard Solo 2 DL and the motorcycle plug & play logger kit differ?
Although both versions of the Solo 2 DL provide precise GPS lap timing and data logging, their differences lie in the ECU connection. The Plug & Play Solo 2 DL Kit provides direct connectivity with selected motorcycle ECUs, whereas the standard Solo 2 DL connectors (particularly the CAN/RS232 & RPM harnesses) require manual wiring.
If your motorcycle has a compatible ECU, the Plug & Play Kit is the best option for ease of installation. If your motorcycle doesn't have an ECU, the RPM connector in the original kit is the best option.
The Solo 2 DL can work seamlessly with our SmartyCam series for data overlay and high-quality recordings. It can also be paired with an Aim ACC3 to add 4 additional analogue channels for external sensors. Data Hubs can also be added to the system to provide additional CAN channels, which is ideal if you're already using the CAN expansion port. Please see the "Connections" tab for more examples.
