El botón remoto puede interactuar el teclado Pro
Control Your Vehicle At Your Fingertips
The Remote Blink PRO CAN keypad is a high-performance, customisable keypad designed to enhance vehicle control in motorsport applications. Available in 4, 6, 8, 10, 12 and 15-button options, as well as an all-new rotary switch variant, they allow drivers to tailor their control systems to their specific needs.
Please Note: The keypads come blank with no inserts, of which we have an extensive range available.
PRO CAN Keypad
The Remote Blink PRO CAN keypad will enable you to have your very own selected buttons at your fingertips.
Integrating configurable channels, multicolour indicator rings, and the ability to be horizontally or vertically mounted, our keypads have been built to the highest standards for the harshest motorsport conditions.
The PRO keypads are available in 4, 6, 8, 10, 12, 15, and 15-rotary to suit your requirements.
Important: 12-key and 15-key PRO CAN keypads sold from 14/06/2023 will use v2 protocol.
Easy to Read
The keypads feature bright LED indicators, making them easy to read in any situation. The multi-coloured LED status rings allow you to set specific colours to your requirements.
Interchangeable Inserts
Explore endless possibilities with our wide range of laser-etched inserts to personalise your keypad – whether it's for lights, heating, fans, parking, and more. You can set these buttons to react based on parameters set by you; momentary, latching and toggle modes.
Remote Blink PRO CAN Keypad
