This Taipan ECU is fully equipped and ready to take on its second life. The product is in full working order at a reduced price, and has been meticulously checked by our technicians.
Aim Taipan Motocross Engine Control Unit
The Taipan engine control unit (ECU) is our aftermarket plug & play ECU exclusively designed for off-road motocross bikes. Thanks to its high-technology 32-bit core, it represents an important step forward to improve the performance of your motorcycle, without sacrificing reliability and smoothness.
This Taipan ECU is unprogrammed and can be configured for any brand/model of motorcycle you require. You will need the UC Bridge Tuner to enable this process.
Why Choose the Taipan ECU
Engine control requires precision. With its high technology 32-bit core, at 20,000 RPM, the Taipan ECU guarantees precision of 1/10 of a degree: this means an accuracy within 0.8 microseconds (µs) for turning the spark ON.
This precision is the key to guarantee:
  • A very consistent engine rotation.
  • The possibility of repeating dozens of tests at the bench, always obtaining the same result.
  • A perfect reactivity at every minimum change of any point of a map, resulting in more power at the wheel.
Traction Control Strategy
Launch Control
UC Bridge & UC Bridge Tuner
Once the unprogrammed Taipan ECU has been configured with a dedicated brand or model, it cannot be changed. You will be able to modify the maps written into the ECU, but the brand or model which has been configured cannot be changed.
Our leading motocross ECU provides the ultimate control in ignition, ignition phase, start maps, launch control, traction control with altitude, and engine temperature corrections.
The UC Bridge is the perfect solution for riders who want simple, reliable ECU management. With it, you can easily flash maps from your tuner, monitor ECU status, and make basic adjustments like fuel injection corrections – all without the complexity of advanced tuning.
For tuners, the UC Bridge Tuner takes things to the next level. It unlocks full control over map creation, modification, and ECU configuration, giving tuners the flexibility to deliver completely customised performance setups.
Taipan ECU Connections
The Taipan ECU has 4 connectors:
  • Main Connector: Compatible with most off-road bikes.
  • CAN Connector: Connects to the Handlebar Switch 2 and Data Logger.
  • 2nd CAN Connector: Connects to the UC Bridge to communicate with the PC.
  • 3rd Connector: Connects to spare analogue inputs and a possible second injector.
Handlebar Switch 2
The Aim Handlebar Switch 2 is the best way for changing the behaviour of your motocross bike. It features 4 push buttons, 11 integrated LEDs, and manages the following settings:
  • Up to 5 selectable maps
  • Apply fuel corrections
  • Activate traction control
  • Activate launch control
The Handlebar Switch 2 can also be used as a shift light module.
  • Two 0-5V analogue inputs sampled at 1,000Hz each - could be alternatively used as a switch to ground
  • One low-side driver (1A)
  • Two CAN bus - one for calibration purposes, one for expansions (Aim Handlebar Switches, data loggers, dashes etc)
  • Three JST JWPF waterproof auxiliary connectors
  • Power Consumption: 150mA
  • Body: PA6 + 30% glass fiber
Connectors
  • 1 JST 04T-JWPF-VSLE-S connector
  • 1 JST 08R-JWPF-VSLE-D connector
  • 1 JST 04R-JWPF-VSLE-S connector
  • 1 33-pin male connector
  • Weight: 260g
  • IP67
Videos
Cargar video: Plug & play installation of the Cobra ECU (now Taipan)
Taipan User Guide
Taipan Tech Sheet
Tuner User Guide
Spark Tuning Software
