Registrador de tablero LCD Second-Life Ex-Demo MX UTV
Aim MX UTV Data Logger
The Aim MX UTV is a data logger display that has been specifically designed for off-road racing. It uses your vehicle’s ECU to acquire all the data you need to improve your racing performance.
Why Choose the MX UTV Dash Logger Kit
The Aim MX UTV dash logger has been specifically designed for the off-road world of racing. It has been engineered to offer the best technology to racers who crave the off-road experience.
The integrated GPS receiver has been tuned specifically for UTV’s and is designed to handle vibrations, direction changes, and all the lateral and longitudinal accelerations that are thrown at it.
To compute lap times, the MX UTV data logger uses GPS and Glonass data to the precision of 1/100 second. If the track you’re on is not already in the database of over 4,000 tracks, you can input coordinates or use the track recognition function that can work out the start and finish line position.
Advanced Dash Display
The MX UTV dash logger features a wide LCD screen offering a choice of 8 configurable RGB backlights. It also has an ambient light sensor that automatically switches the backlight on when encountering low light conditions, ensuring you always have maximum visibility. The 4.3" display is wide enough and bright enough to see all the data you want to see while you’re racing.
Transmission Belt Temperature Monitoring
An included infrared sensor monitors the transmission belt temperature, providing alerts if the temperature approaches critical levels.
Transmission belt temperature is one of the main concerns for UTV drivers. The infrared temperature sensor in this kit makes it possible to constantly check the temperature on your dash display while you’re racing.
The configurable RGB LEDs at the top of the MX UTV dash logger will also turn on when the temperature gets to the critical level.
The MX UTV can be backlit in one of eight available colours; it also features an ambient light sensor that makes brightness and contrast ideal in all light conditions.
The MX UTV can also swap among pages showing lap times and data in a customisable way to suit your needs. Choose the data and create pages displaying up to eight fields in each. You can visualise the rolling time or static or predictive lap time (as an absolute value or as a difference vs. the best lap.)
Configurable RGB LEDs
The top of the MX UTV dash features 5 LEDs. These can be configured to be used for 2 different functions - gear shift light or predictive lap time.
- If you configure the LEDs for gear shift lights, this will help you choose the best time to shift gears.
- If you configure the LEDs as the predictive lap time, they will give you a constant idea of how you are improving your lap times.
While allowing RPM monitoring at a glance, the alarms are flexible too. You can configure the situation that generates the alarm as well as the LED behaviour (blinking, frequency, and colour) when the alarm appears and the conditions for its switch off.
Integrated GPS
The MX UTV data logger features integrated GPS, which enables the MX UTV dash to automatically recognise the track you’re racing on. The dash will calculate lap times and your position on the track, and locate the start and finish line position. All your data is stored in the 4GB memory, which can log your data for several thousand hours.
Expand your MX UTV's capabilities with a range of compatible accessories to guarantee precision and reliability.
MX UTV Dash Logger
CAN & Power Cable
Single Point Belt Temp Sensor with Fixing Kit
Sensor Extension Cable
