Link Combined Pressure &Temperature Sensor
The Link combined pressure and temperature sensor integrates two sensors in one: a 10 bar (145 PSI/1,000 kPa) liquid pressure sensor and a -40 to 140°C (-40 to 284°F) liquid temperature sensor. It is suitable for use with oil, coolant, fuel, transmission fluid, and other liquids.
Why Choose the Combined Pressure & Temperature Sensor
The Link combined pressure and temperature sensor features an M10x1 fitting with a 45-degree cone seat for secure, leak-free installation and is supplied with a Bosch Trapez 4-pin mating connector kit for easy and reliable wiring.
It is an ideal option for performance or racing vehicles, where space is limited, and real-time, accurate engine data is crucial for optimal performance and safety.
  • Suitable for diesel, gasoline, E85, engine oil or transmission oil
  • Up to 10.0 bar (145 PSI/1,000kPa) pressure sensor for liquid
  • -40 to 140°C (-40 to 284°F) temperature sensor for liquid
  • 45-degree cone seat, M10x1 fitting
  • Includes Bosch Trapez 4-pin mating connector kit
  • Not suitable for water/coolant
SKU: CPTS
Descargas de enlace de PC
