Mount Your System
The Suzuki Motorcycle Bracket has been specifically designed to provide a simple and secure mounting solution for Aim Solo 2 and Solo 2 DL Lap Timers. The bracket is compatible with Suzuki GSX-R 600 (from 2004-2023) and GSX-R 750 (from 2004-2017) motorcycles.
Why Choose the Aim Solo 2/2 DL Motorcycle Bracket
The Aim Solo 2/2 DL Motorcycle Bracket ensures your Solo 2 GPS Lap Timer can be securely mounted on your Suzuki GSZ-R motorcycle. Supplied with all the necessary hardware, it provides a quick and stress-free installation, so you can accurately track and monitor your laps with ease.
Suzuki GSX-R Motorcycle
Plug & Play Cable
A separately sold plug & play cable is also available for the following Suzuki motorcycle models:
  • GSX-R 600
  • GSX-R 750
  • GSX-R 1000
  • GSX-R 1000 L7
  • GSX-R 1300 Hayabusa Gen.2
If you are unsure whether this bracket will fit your motorcycle, don't hesitate to contact our team.
  • For Suzuki motorcycles only
  • Compatible with GSX-R 600 2004-2023 and GSX-R 750 2004-2017
  • Mounting bracket for the Solo 2 & Solo 2 DL Lap Timers
SKU: SUZ-B
Part Number: X46KSSGSXR
  • Soporte Suzuki Solo 2/2 DL
  • x1 Tornillo Allen de cabeza redonda M8x45mm
  • x2 tornillos Allen de cabeza plana M4x10mm
  • x1 Arandela dentada
  • x1 pasador de goma
Suzuki GSX-R User Guide
Suzuki GSX-R L7 User Guide
