Programador portátil de TPMS
TPMS Programming Unit
The TPMS Programming Unit is a compact device that can be used with Tyre Pressure Monitoring Systems (TPMS) to program replacement or additional TPMS Sensors.
Why Choose the Aim TPMS Programmer
The Aim TPMS Programmer is necessary for anyone running an Aim TPMS system who needs to manage multiple sets of wheels or perform on-track diagnostics to ensure optimal vehicle performance. The TPMS programmer is used for direct reading of sensor parameters such as pressure, temperature and battery voltage. It can also be used to program or modify the sensor parameters, such as the team code and wheel location, including the AASL functions.
Note: This Handheld Programming Unit is FREE when purchasing 16 or more sensors.
TPMS Programmer
