Yamaha YZF-R1 2009-2014 AIM SOLO 2 DL & EVO4S Data Logger Plug & Play Cable
Choose Accessories
Yamaha Motorcycle ECU Connection
The Yamaha ECU Plug & Play Cable allows you to connect Aim Data Loggers, such as the Solo 2 DL, ECULog, XLog or EVO4S, to the Yamaha-specific connector. The Yamaha ECU Cable provides an easy plug & play connection to the motorcycle's ECU on one end, and uses a metal 712 screw-on binder connector with 7-pins on the other end, allowing ECU data to be logged.
Plug & Play Cable
The plug & play cable has been specifically designed for the following Yamaha motorcycle models and years:
- Yamaha YZF-R1 (YEC included) – 2009-2014
Example Data Protocols
Example data protocols sampled can include RPM, wheel speed, water and air temperature and more. Refer to the user guide in the Downloads tab for a full protocol list.
Yamaha R1 Solo 2 DL Plug & Play Cable
