IVA-Compliant Digital Dash Display
IVA-compliant displays are essential for road-legal OEM kit cars and racing vehicles in the UK, ensuring compliance with the Individual Vehicle Approval (IVA) standards.
These digital dash displays offer compliance with road legality standards, simple plug & play installation and connectivity with the kit car's ECU to enhance performance - all possible by the IVA-specific second harness that comes with the display kit.
The MXT Strada 10 inch Display integrated into a car dashboard on a racetrack
Why Choose the Aim MXT IVA-Compliant Dash Display Kit
The MXT IVA-compliant dash is part of a range of digital displays, specially designed for kit car drivers who need essential data visibility while on the road. They show real time data such as speed, RPM and temperatures, but they don't include data logging functionalities natively. To extend their capabilities to log data similar to the full display loggers, a Strada Logger Kit is required.
The MXT 1.3 Strada IVA display is available with a choice of connections. Choose either the OBDII or K-Line CAN, depending on whether you want to connect to the kit car's ECU or OBDII port or directly to the ECU through the CAN channel.
You can sample and display dozens of channels straight from the ECU with only 2 cable connections to the ECU instead of multiple connections to analogue sensors. The sampled data depends on the actual ECU, but will typically include RPM, throttle position, oil, air, water temperature, oil pressure, battery voltage, speed, gear, and lambda value (air/fuel ratio). The list of available ECU drivers is 1,000+ and is constantly being updated.
Digital Outputs
The MXT 1.3 Strada IVA display features a 1 AMP digital output configurable to be activated/deactivated depending on the value of the analogue/digital inputs or on the impulses coming from the ECU. This allows you to automatically run external systems, such as switching on/off additional lights, to activate/deactivate a cooling fan or circulation pumps when a certain event happens.
Charger la vidéo: Delta times LED display feedback on the MXT 10 inch Strada Display
Charger la vidéo: Integrated shift light array interface and customisable alarms for the MX Strada Series
Display with Road Icons
The MXT 1.3 Strada IVA-compliant dash has a 10" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels.
Charger la vidéo: Pre-configured dash display screens for the MX Strada Series.
Pre-Configured Pages
The MXT 1.3 IVA Dash shows the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can customise pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy; just use the push buttons.
  • All channels
  • ECU drivers
  • Math channels
  • Display pages
  • Digital outputs
  • Alarms
  • Shift lights
  • Expansions
Turn your MX IVA Dash into a complete data logging system with the MX Strada Logger, Data Hub & GPS09 Module. You can also integrate an ACC3 and convert your analogue to CAN, integrating a camera and various sensors into your setup.
  • Ambient Light Sensor: Yes
  • CAN Connections: 2
  • Digital Inputs: 4-speed input, lap signal, coil RPM input
  • Second CAN: Yes
  • Body: Anodised aluminium
  • Connectors: 2 AMPSEAL connectors & 1 binder connector
  • Power Consumption: 450mA
  • Display: 10" TFT
  • Resolution: 1,280 x 480 pixels
  • Contrast: 1,100:1
  • Brightness: 800cd/m²
  • Weight: 1,100g
SKU: MXT-IVA-CAN
Harness Options
MXT Strada User Guide
MXT Strada Tech Sheet
IVA Loom Diagram
What are the differences between the MXT Strada IVA-Compliant Displays and the MXT Strada Display?
The main difference between the MXT Strada IVA-Compliant Display and the MXT Strada Display is that the IVA version has an IVA-specific second harness that comes with the display kit, providing essential road lighting indicators (turn signals, fog lights, etc.) to meet UK Individual Vehicle Approval (IVA) standards. While both have a 10" display and ECU compatibility, the IVA dash provides a plug & play solution for road-legal kit cars. For a full comparison of the MX Strada Series, take a look at the comparison tab.
What is an IVA Approved Dash Display?
IVA-compliant dashes are a range of digital displays that ensure compliance with the Individual Vehicle Approval (IVA) standards, specially designed for kit car drivers who need essential data visibility while on the road. They show real time data such as speed, RPM and temperatures, but they don't include data logging functionalities natively. To extend their capabilities to log data similar to the full display loggers, a Strada Logger kit is required.
MXT Strada IVA Compliant
MXG Strada IVA Compliant
MXP Strada IVA Compliant
MXS Strada IVA Compliant
  • 10” TFT display
  • 10 shift light RGB LEDs
  • CAN output
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 7" TFT display
  • CAN output
  • 8 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 6" TFT display
  • CAN output
  • 5 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • 5" TFT display
  • CAN output
  • 6 alarm RGB LEDs
  • 8 analogue inputs
  • Configure data
  • Weight: 1,100g
  • Weight: 950g
  • Weight: 590g
  • Weight: 480g
  • IP67
  • MXT Strada Dash
  • 14-Pin Standard Wiring
  • 23-Pin IVA Loom
  • MXG Strada Dash
  • 23-Pin IVA Loom
  • MXP Strada Dash
  • 23-Pin IVA Loom
  • MXS Strada Dash
  • 23-Pin IVA Loom
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Second CAN: Yes
  • Power Consumption: 400mA
  • Second CAN: Yes
  • Second CAN: Yes
  • Display: 10" TFT
  • Contrast: 1,100:1
  • Display: 7" TFT
  • Contrast: 1000:1
  • Display: 6" TFT
  • Display: 5" TFT
